New Jersey Diesel mechanic
Hello Faithful,
My brother is looking for a good reputable diesel mechanic to work on his Volvo diesels. The motor are the 41 series (200HP) versions. The boat is located in Brick New Jersey. One the way home from his last canyon run he could not get the motor started. He tried bleeding the fuel system and she would still not fire up. He started limping home on one engine and put the nonrunning engine in gear and then tried starting it and it worked.
Once started the boat ran fine all the way home. Thank you for any help.
Chris Holgerson
Chris Holgerson
- Skipper Dick
That would be my guess also if the motor does'nt turn over. I've had it happen and was able to tap the switch a little and get back. I didn't take a chance it would work a second time so, I replaced it. Took a couple of minuts. Now I carry a spare. You'd think these things would last forever because there isn't much to them.
Dick
Dick
Carvers uses the local cummins dealer.
The mechanics name is Chuck we get our parts through him, always been nice to deal with.
Give Chris or Libby a call 732 892 0328 they can either schedule the boat at their place or give you Chucks information directly.
Does Volvo use a fuel solenoid?
You can also try John. He used to take care of a fleet of tugs and commercial vessels for one of my customers. Thats before going out on his own in the Jersey area. I have recommended to several people with great results.
John- 609.276.8601
Tell him you where recommended by Carl at Staten Island Machine.
John- 609.276.8601
Thank you for all of your replies and recomendations. We are going to try and do a little more trouble shooting before he takes her to a mechanic. We are thinking it is sometype of leak on the suction side or a bad injector. There is no fuel solenoid on the boat. If anybody would like to help here are the conditions again
200 HP Volvo Diesel
Motor will not start, blows white smoke out of exhaust while cranking over.
The motor will start with a little help from starting fluid.
Once started the motor runs strong with no problems.
Thanks for any help.
Chris
200 HP Volvo Diesel
Chris
Could it be stuck in gear or tranny clutch plates warped not allowing engine to crank at speed. Underway allows it to crank at speed, but when not moving its being held back by gearing and prop?
Not even sure that is possible never mind likely, I'm sure others will chime in. Maybe disconnect shaft coupling from tranny and give a try
Users browsing this forum: Google [Bot] and 372 guests
