Two items for your purusal and advice.
Spoke with Alex Whittaker about my rub rialproblem and if you're considering a new one give him a call.
Second, once the original rub rail is removed and boat prepped, how many hours should it take to install a new PVC rub rail?
Rub rails
Install is pretty straight forward. Layout is a couple of hours, figuring the miter cuts is pretty intense and depending how good you are could take a few hours as well.
With the right clamps, hardware, caulk and layout complete its 2 guys a little over 8 hours. +/- for joint work.
Then the stainless (this is where you figure out how good your layout was).
I thought the number was around 5.5k to have a yard do it and that was including the materials.
- JohnCranston
Users browsing this forum: Google [Bot] and 78 guests
