looking for copper bonding & a rubber type gas tank supp
Hi everyone, After taking the summer off I'm back to work on the 28' the engine stringers are in and Im about to install the new gas tanks. I am looking for 1/4" - 3/8" thick rubber, or neoprene strips [or what ever will tolerate fuels] approximately 3/4" wide to rest the tanks on. I also need about 50' of the bonding copper. Any suggestions where to find these would be greatly appreciated. Thanks
If your going to put an elastomer under the tank:
>Use a fairly hard material, 1/4" thickness is plenty.
>Use an NBR based compound (Nitrile Buytal Rubber)
>Do not use EPDM based compound (hydrocarbons will eat this stuff up)
I would suggest calling a gasket company. Try http://ghxinc.com/
I have used these guys for years for gaskets, hose, etc.
Good Luck
Good Luck
I never thought worst marine would carry the copper bonding. Thanks I will stop in.
Scot, the aluminum tank is powder coated, it is partially sitting in the bottom part of the original fiberglass tank [I installed a drain plug in the glass tank in case condensation, etc. gets inbetween the tanks. I was going to glue the rubber, etc, strips to the aluminum tank. I will not use a EPDM caulk. One question, what is a EPDM caulk?
Users browsing this forum: No registered users and 157 guests
