repowering the PLAYPEN
just blew a motor on sat.been having problems all summer so now decision has to be made to repower,leaning towards 315hp yanmars.questions i would like answered;
1 what should my 31 cruise at?
2 what gear ratio trans?
3 what size shafts
4 props.
5 boat is in o.c.n.j. who can install?
6 what are my 250 cummins and trannys worth,1990 with approx.2450 hours,1 runs great,1 seems to be aqua locked.
thanks,any and all help is appreciated
charlie
3 what size shafts
4 props.
charlie
Charlie,
1 what should my 31 cruise at? -- 28 to 30 kt (32 - 34 kt wot)
2 what gear ratio trans? -- 2:1
3 what size shafts -- 1 1/2" (perferably Aquamet 22)
4 props. -- Start with 20x24 4 blade
The Yanmar 6LPA is one of the models that is being affected by the tierII EPA regs & may not be available much longer, (if it hasn't already dissapeared from the new market), and the new common rail fly by wire replacement may be your only Yanmar choice.
Charlie,
I can confirm Patrick's comments since he and Bruce handled my repower. I have the 6LP-STE 315s and I cruise at an honest 30 knots (full fuel, full water, four guys, cooler, moderate amount of gear, bimini top) using the setup Patrick described. Needless to say, I usually find it more comfortable to cruise in the 24-26 knot range, and slower per the sea conditions.
Tommy
Tommy
Charlie-why would that be? I have 210's and cruise at 21-22. Vic has 250's and cruises at an honest 24-25. I think he's propped with 21X24's. or 20x24's. I'm pushing 20x20's lightly cupped and am probably underpropped. Mine is the older heavy hull with a heavy teak deck. You should be cruising faster than that. Walter
315 yanmars
1. cruise most of the time - 26 to 28 kts.- !975 model- 231 gal. fuel
2. gear 2:1
3. shaft 1.5"
4. 4 blade Nibral, 20x23
5. installer: Tim Silveo @ Down Jersey Marine Services.
Jimmy G. & i had him do our installations.
He has the best reputation in the NE. Office # 856-451-7961
Cell # 609-319-2283
Good Luck
2. gear 2:1
3. shaft 1.5"
Cell # 609-319-2283
Good Luck
I would ask yourself what you want to cruise the boat at speedwise, and what speed you think the waters you travel will allow you to cruise at most of the time, and then I would size the engines appropriately.
If you have a boat that will cruise at 30, but you can't use it at that speed, what good does it do? If you think you will spend 95% of your time cruising at 24 knots, not 30, then the 315's are the wrong engine...
Just some advice.
Otherwise they are great engines! the 240's allow more room to work around them, and are a bit more stingy on fuel, but the cruise is about 4-6 knots less depending on where you put the throttles. They work for me because in NE, I am not always able to cruise at 30 knots. More like 22-24 without killing the boat or me.
Just some advice.
cost
ed c
i am meeting with tim wed. night,i have a question. could you share the approx. cost with me. if you dont want to post it email me
thanks
charlie
thanks
charlie
Users browsing this forum: Google [Bot] and 361 guests
