D4s in a 25?
D4s in a 25?
I posed this question to the guys on the Bertram 25 website.
I am considering putting twin Volvo diesels in my inboard 25. Here are the choices:
D4 (180 hp) 2800 RPM rating 4 cylinder
D3 (190 hp) 4000 RPM rating 5 cylinder
I was told by one of the guys on the 25 webste that Bruce has repowered a 25 with D4s. Bruce, could you give me some more information on how that repower worked?
Scot, you have posted in the past that you thought anything more than 350 total HP is too much. Should I consider smaller D3s?
What do you all think about higher vs. lower HP, higher vs lower RPM rating and the diffence between 4 and 5 cylinder in terms of noise and vibration?
Davidms
Davidms
Check this guys project... Cummins single. 330 hp. Id move the helm forward.
(Ever drive a 25 from lower station?? )
http://www.cssims.com/JG6B.htm
I believe that anything over 350hp (diesel) is basically wasted in a 25B. The hulls just don't require a lot of power to work well and the design speed of the hull is not very high, maybe mid-30's? Jim's 6BTA 315hp, 1.5:1 gear and 20x23 wheel is one strong machine. I basically know nothing about Volvos.
My comments would be directed to inboard configured boats. Are you considering re-powering a 25 V-drive inboard?
I'm the wrong guy to discuss I/O's with because I really don't know very much about them. As a rule they don't do well when left in the water and require much more attention than inboards. They are faster but not one of my favorite drive drains by any stretch. I like boats that can be left in the water and are simple....like me.
David...D4. I like slower turning diesels (I'm old school) and it should be an easier fit? Give it a try, we all want to see how it comes out. There is a lot of discussions about re-powering the twin V-drive boats with diesel.
Rocket,
I'm not saying they won't go there...I'm saying they don't need vast sums of HP to perform well. "REAL" speed is a different story and YOU are the man to talk to about that!.....geez, a 62mph Baron!
Rocket,
In 1984 I pulled the orginal 165 Mercruisers out of my B25 and installed a pair of Vulva AQAD31 diesels with the Duoprop outdrives. Made her stern heavy and got about a 21 kt cruise, but only burned 8 GPH at that speed. Doel-Fins and big trim tabs helped get her level at speed. The engines were 110 hp 4 cyl. turbo & aftercooled. Engines drove me nuts with the 4 cyl. 4 stroke "rattle" and parts constantly fell off the motors. Plus a very tight fit made maintaince a headache. Parts were stick-em-up expensive and the whole deal cost me in excess of 20K back then. On the other hand, Da Judge put gas Mercuriser 4 cyl. 135s with Bravo Ones in his B25 for short money and it runs better than my diesel one ever did. On a 110 n.m. trip from my camp to Venice running together, my B31 with Cummins 250s burns 83 gallons and he burns 55, both of us running 24 kts, and we have done the trip 3 or 4 times together.
Too much motor money for the boat.
Users browsing this forum: No registered users and 402 guests
