'73 35B tank replacement underway
Well so far, I've cut the deck out, it had rot in a couple of places anyway, damn cheap bertams, only lasted 33 years! Will replace with nidacore FRP panels over 2" square FRP tube webbing. Cut the tabbing from the front and rear bulkhead and corners or the tank (it's athwartships) and removed the rear bulkhead. Found that a plywood panel was installed about 8" in from stringer to stringer and the tank was bedded in with, I assume, polyster putty. After much consternation, ended up cutting a bunch of wedges from 2x4 and driving them under the tank over top the stringers which lifted the top layer from the plywood but finally popped it out. So now I have a 258 gal tank in the back of my truck trying to give it away to someone, hate to cut it up - trying to interest local farmers for diesel storage or farm chemicals or soemthing. Have measured out for aluminum tank, will pick up an inch here and there and about 40 gals, sorry no pictures yet. Alan.
Alan Ormond
1973 35'
Va Beach, VA
1973 35'
Va Beach, VA
Al, lifted it out w/the yard's forklift & docklines so we really didn't try, I could lift one side fairly easily but we couldn't figure where stand to lift it by hand and pressing it up to the gunnels and getting down the dock was going to an iffy proposition. i'd say no more than 125lbs. When I pull it of the truck I'll have better idea. Alan.
Alan Ormond
1973 35'
Va Beach, VA
1973 35'
Va Beach, VA
Hi Alan,
Sorry to year you had to pull the tank. I'm facing the same thing in my B35 but am waiting until this fall/winter. Fortunately my deck had already been replaced with an aluminum insert and comes out real easy. I had a leaky aux. tank in front of the main a few years back, so my front bulkhead is all brand new and overbuilt :( So if I do replace it I'll have a lot of cutting to do on the front.
While you're in there are you going to re-paint/fix other stuff?
I know balance means a lot in the boat, but I'm considering moving the Generator to in front of the tank and then expanding the tank about 15" further back for more capacity.
Keep us posted as to what size tank you go with or any other tips.
Another question, what motors do you have? I have crusader CH350's (454's) from the late 80's.
br,
JohnD
br,
JohnD
Hi John, about all the additional work I'm going to do is scab in on the front bulkhead where the AC units have been dripping fresh water and it runs onto to the cleats, other than that, pressure wash and epoxy some glass on the plywood the tank sits on and go. I removed the generator years ago, it actully ran but I never used it and I wanted the space for a 55 gal. spare tank. The new tank will be approx. 300 gals which should help my balance as well. When I put the Merc 8.1s in the balance moved a bit (a bit lighter and the ZFs are shorter than then BWs) and I swear the boat is happier w/a full load of fuel. Couldn't make the tank much wider w/out getting over the strut pads but picked up a couple of inches here and there. Did manage to give the old tank away, guy'll be using it to transport diesel to his equipment. Regards, Alan.
Alan Ormond
1973 35'
Va Beach, VA
1973 35'
Va Beach, VA
I agree about the weight and found this supported by other B35's with diesels especially Cats.
I believe my balance was upset a little when the previous owner moved the ac units and batteries over the water tank. Then added an extra 110gal in front of the old tank where the AC units had been. When both tanks were full she sat level in the water. Now with the extra tank removed (it leaked) there's a slight bow down when the main is anything but full.
Good luck with your project.
Users browsing this forum: Google [Bot] and 19 guests
