Auto-pilot and Steering
The other possible winter project....I'd like to put in a whole new steering system and autopilot. Recommendations? Thanks. Its either this or windows.
This may help- all the same company, teleflex.
http://www.downloadingfiles.co.uk/telef ... 001-12.pdf
We have had years of success with the sea star system, very simple and no pump
Was out on my friends boat with the ap-11 recently and found that our ap-16 performed far better
Don't know what type of boating you do, but for me the addition of the autopilot was revolutionary
For a B31, I'd consider a raymarine package. You could go with the SG1 and get the head unit, course computer, hyd pump for under $1500 and then add their wireless remote.
In the bay and mostly for remote steering you'd probably be fine without the gyro-compass. Though I would ask if it could be added later if needed.
Also, during the Annapolis Boat Show you may be able to shave a little more off the price. I've also bought from Consumers Marine in Jan during the Miami show, they have boat show pricing on their website.
br,
JohnD
br,
JohnD
look into the tr1 autopilot here is there website http://www.nautamatic.com/
If you don't have an autopilot and put one in, you'll wonder why you hadn't done it sooner. From being able to eat a sandwich or light a cigar while running out to the grounds to being able to run down into the cockpit to net or gaff a fish your kid caught. You'll probably actually save on fuel by running straight lines rather than wandering from port to starboard. When linked to your GPS you'll go from point to point straight as an arrow. Lose an engine and you'll avoid wrestling the wheel to run a straight course. If your windows aren't rotting out and you can only afford doing one, I'd do the autopilot. My opinion. Walter
- Dave Kosh R.I.P.
Sorry but Hynautic steeirng is the best. Anything with a pressurized canister that tells you whats going on is better then the best closed (potentially leaking) steering system on the market today. The new rams don't make the turns or perform near as well as the old hynautic systems.
In order to meet or exceed the performance of the hynautic system you need to move to power steering.
When was the last time you went 5 turns lock to lock on a helm set up.
Couple that performance with anyones half ass autopilot and they all will perform.
Put it with a Simrad or TR1(Garmin) and you get nothing but performance ++++++.
Sometimes older is better.
I'm only familiar with the Sea Star. I can't speak about the Hynautic but It's hard to imagine anything better? 5 years of effortless steering without a hitch. Works as good as the power stering in the truck. Super easy for dual station installation.
You can make your long runs with refrigeration grade soft copper tubing, cheap and no problems. Standard 3/8" compression fitting from the copper to the flex hose.
As I mentioned I don't know about Hynautics, but I can vouch for the Sea Star.
I've never gone 5 turns lock to lock with the sea star because its 3 1/2 turns. Don't have to look at a gauge to know you have a problem, which has happened exactly one time in the 15 or so years since we installed it.
If you need to add oil, just unscrew a cap right at the wheel. That has happened exactly one time also.
KISS
KISS
Users browsing this forum: Bing [Bot], Google [Bot] and 302 guests
