heres a good lesson
heres a good lesson
spent two hours at the boat last night with my friend the mechanic..... and what i accomplished was i learned some new tricks for testing continuity...i learned how to increase voltage by increasing distance....i learned lots about my carb ... i learned my engines will run all day on 5 cylinders....did not however learn what was wrong.....go back today and switch modules in an effort to eliminate that.....take the module from the good engine(starboard) and put it in the bad running one.(port)...as im putting the new module (which i put in the bad running engine (port) when it died completely)in the good running engine i notice a very small amount of un insulated ground wire showing where it looks like it got crushed by the retaining screw the first time around...wraped with tape and installed......both engines run again.........duh
my friend rattled off a formula....said it was couner intuative watch this...............stuck a phillips head screwdriver in the coil terminal on the distributor cap......took the wire and moved it closer and further from the screwdriver while the engine was running.......the spark got hotter as he moved it away (to a point)........went around the cap doing the same with each plug wire.....easy to see which were firing and how strong the spark was
I think the air gap increases the resistance so the coil builds a higher charge before it can discharge across the gap, hence higher voltage (or is it amps, I can never remember). I put Acce supercoils(the big yellow ones) on mine when they needed replacing and they work great. Ask me how I know they will raise the hair on your head!
- AndreF
Randall,
Is that because of the frasnoids being longer than the resonance descant factor and conversly profluent releasing of rolamite energy?
Or is it the opposite?
1981 FBC BERG1883M81E
- Capt. Mike Holmes
Current thinking
I think you nailed it, Andre!
- thuddddddd
- Capt Dick Dean
Users browsing this forum: Google [Bot] and 185 guests
