Moderators: CaptPatrick , mike ohlstein , Bruce
thereheis
Posts: 244 Joined: Jul 1st, '06, 05:37
Post
by thereheis » Aug 28th, '07, 20:37
i lost my gel-kote activater( hardner )... what can i use ???or should i use??
phil
Posts: 4161 Joined: Jun 7th, '06, 14:25
Post
by CaptPatrick » Aug 28th, '07, 20:41
Phil,
MEKP, same as polyester resin, (which is what gelcoat is...). Mix ratio is 3% - 4% depending on ambient temperature.
thereheis
Post
by thereheis » Aug 28th, '07, 20:47
i figured as much ,but wanted to make shure..you about dried out up there? i am headed home tommorow for a week ,,,,gota bail the front yard,then back to port a . got the boat in the covered shed for awhile...waiting for good weather and the white run in sept,,,,thanks again....
phil
Post
by CaptPatrick » Aug 28th, '07, 20:50
Phil,
Nice & dry up here, only a couple of inches this month...
thereheis
Post
by thereheis » Aug 28th, '07, 20:55
dry down here also got lucky on the hurricane,,
phil
Marshall Mahoney
Posts: 241 Joined: Aug 9th, '06, 20:44
Post
by Marshall Mahoney » Aug 28th, '07, 21:35
Also -- use the wax additive if the surface gelcoated is exposed to air. Avoid letting it cure in direct sunlite if possible. Both could lead to a tacky surface. I found using a little extra MEKP for a faster batch is better.
Mack
Posts: 212 Joined: Jun 30th, '06, 13:28
Post
by Mack » Aug 29th, '07, 08:35
Pretty work.
Skipper Dick
Posts: 330 Joined: Jun 29th, '06, 08:22
Post
by Skipper Dick » Aug 29th, '07, 08:41
Phil,
Outstanding job. One almost hates to get fish blood on the deck when they look like yours does.
Dick
ZeroCavity
Posts: 204 Joined: Jul 10th, '06, 14:36
Post
by ZeroCavity » Aug 29th, '07, 08:54
Phil : Beutiful Boat !!!! Can you post more photos ? Will like to see your flybridge with more detail.
Users browsing this forum: No registered users and 342 guests
