Toxic Smurf
Toxic Smurf
http://share.shutterfly.com/action/welc ... lY¬ag=1[/img]
I thought you guys said soda blasting was easy. Click on the link. 2 pictures are soda blasting in action. 1 picture is a message to whoever talked me into it. Click "View Pictures" then "Slide Show."
Marshall,
5 years ago, when I got Windstar, she must have had every coat of bottom paint ever applied.
The method I used was Interlux Pintoff, which is a gel that is brushed on, left to sit for several minutes and then scraped off.
After the Pintoff has removed as much bottom paint as it could, I then sanded the rest down to bare glass. This process
took me roughly 8-10 days (from sunrise to well after dark) to complete.
Soda or any other type of bottom blasting is far easier than the approach I took, however, my approach is the least expensive.
The only easier way to do the bottom is to have someone else do it, which is my appraoch the next time it has to be done.
However, no matter which way you clean the bottom, the results are well worth it.
Harv
It is easy, but you forgot the MOST important step, have someone else do it.
Did mine several years back, chemical was TOO slow for me so I did a light grind and lots of sanding. Yeah...defintely need to follow step one next time. Although now I use the ablative and not much of it, really keeps buildup down and I have little growth.
Marshall,
I Soda blasted mine with a pressure washer with a 5 G.P.M. water flow with a separate vat with the soda blast in it, I didn't look like you after blasting, just look like I was playing in the water hose from getting wet.
But good luck, it was looking good when I came by going to Faux Pas down in Venice. Was talking to Mr. Skeets down in Venice and he said; his son works with you at the plant.
DQ
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Oven Cleaner
Neatest job I ever saw was by a guy in my marina several years ago. He used oven cleaner. Bought cases of the cheapest stuff he could find. Very slow process, since he had to do small sections, multiple times to get down to glass. He is retired and did the work over a winter. But in the end, he had stripped about 15 years of paint off the bottom of a blubliner and the bottom looked like brand new.
unabashed hyena lover
Re: Oven Cleaner
That's probably cheaper than the way I did it. However, the process is almost the same as with the Pintoff. I used Easy Off to remove the old name on the transom. The only thing to remember with Easy Off is to rinse with lots of water. Besides eating paint it will also eat gelcoat.Jack wrote:Neatest job I ever saw was by a guy in my marina several years ago. He used oven cleaner. Bought cases of the cheapest stuff he could find. Very slow process, since he had to do small sections, multiple times to get down to glass. He is retired and did the work over a winter. But in the end, he had stripped about 15 years of paint off the bottom of a blubliner and the bottom looked like brand new.
Harv
Did I mention that I killed the $&@* out of my neighbor's lawn?
I looked at fine sand but to much dust for neighborhood blasting. The whole process took about 6 hours. The trick was getting finished before 5:00 when people came home from work -- it was not a discrete process. (Don't you wish you had neighbors like me)? I tried several paint removers but did not have much luck (the gentle ones were a joke and the strong one even softened the gelcoat so be carefull if you go this route). I would still reccomend blasting vs sanding or stripping -- due to minimal time/effort (that 5# sander gets REALLY heavy). Harv -- I'll be happy if my hull comes out a fraction as nice as yours!
Marshall,
for the final touches, I used a handheld Ryobi orbital sander. Very light, with a 5 1/2 inch disk. Used 80 grit for the leftover paint and 120 grit to smooth it all out. Actually, I would have been fine with just the 120. Ironically, that was the last year the yard (by law?) allowed me to paint my own bottom, and it has never come out as good since. Plus the fact that the yard seems to need 1 1/2 times the amount of paint that I used.
Harv
Users browsing this forum: Google [Bot], Yannis and 460 guests
