After leaving town for two weeks I came home to find the helm pump leaking oil from the shaft. Need a new pump, or to rebuild the existing one. Seemed easy enough.
Problem is, I can’t get the offending pump out.
Instead of trying to type a paragraph I drew a (bad) picture, and have some factory diagrams too. We’re talking about a Hynautic H-50 pump, on a B33, which is set up very similiar to a B28:
![Image](http://i11.photobucket.com/albums/a175/Burlingham/temp%20pics/ITHelmPump01.jpg)
![Image](http://i11.photobucket.com/albums/a175/Burlingham/temp%20pics/ITHelmPump02.jpg)
![Image](http://i11.photobucket.com/albums/a175/Burlingham/temp%20pics/ITHelmPump03.jpg)
I removed the steering wheel and the four cap nuts, and then the trim ring. Everything I can find tells me that the helm should drop away behind the helm now, but the damn thing won’t budge. I put the cap nuts back on a few turns and hammered on them – doesn’t move. I put the steering wheel nut back on a few turns and hammered on that, same result.
I thought there might be some screws hidden behind the gauge panel, through the plywood backer and into the pump body. So I pulled the whole gauge panel, but no hidden screws. Then I hammered on everything some more, including my pride and my thumbs. The damn thing won’t move.
I removed the threaded studs from the backside in case those Cubans glassed some nuts into the plywood backer. No mystery nuts. I hammered some more. It doesn’t budge, AT ALL.
There is no hint of any 5200 seen from the backside of the pump. I suppose its possible it was set into some epoxy against the plywood, which I would not be able to detect. But this boat is an ’87 and I think I’m the first steward try to remove it. I wouldn't think that they would bed it into epoxy at the factory but who knows...
I feel like I’m missing part of the plot here. Anybody know what it is?
