B31 Rub Rails
- Bertram Joe
B31 Rub Rails
Where can I get the absolute best looking B31 rub rail? I think I prefer white rail over chrome.
Joe,
The PVC guard rail by 31 Bertram Specialties - Alex Whitaker, is designed as a direct replacement of the aluminum rail...
Capt Patrick,
What would the advantage be of installing the PVC replacement rail vs the aluminum rail. Taco appears to have the original extrusion (or pretty close)
The aluminum is less?...looks like $1,000 for the aluminum (no pre-bends) and $1,350-$1,400 for the PVC + SS cap...with the bends already in it.
Is one better than another?
I saw a neat trick at Onset Bay Marine to eliminate drip stains. They cut a piece of heavy window vinyl about 1.5" by 18" long, then they tucked it under the rub rail where the drip lines are. The flap diverts the water away just enough to avoid drips, its clear so it doesnt catch your eye and its flexible when rubbing up against a piling.
Bob H., I did that on my boat when I installed the rail, and it is the nuts!
Raybo, it does make a big difference from the aluminum. When your rail is tired and old, it gets hit with the nice rain from the sky. Any poor alkalinity in that water reacts with the aluminum rail and causes oxidation, which is what is causing some of the stripes.
If you have dirty rain, of course you will see more stripes, but mine virtually disappeared after installing the pvc rail. I find it hard to believe that the air and rain just cleaned up permanently over 1 winter...
I get drips, no doubt. And I keep mine clean.
But the intensity and quantity changed like night and day when the PVC went on.
Call it what you will. I call it the rub rail. No worries, it could be other stuff as well. Who knows for sure. Probably got sprayed with Corrosion X at some point and that solved it...
If you seal the top and bottom of the rubrail with sikaflex or something similiar wouldn't this make the problem go away?
I think Capt Patrick described a technique where you tape out the entire rail (on the rubrail and on the deck / hull side) finger on the sikaflex and pull the tape off.
Very small amount of 'goop' only in the area that you want it.
Ian.
Ian.
A high build, high gloss, properly cured Imron 5000 paint job and the streaks go away, they don't stick...when you start to get some streaks on the Imron after a few years, buff out by hand with a VERY light compound and use ReJex and nothing will stick no mo'. Spider doo-doo will stick some, but rinses off pretty quick, same with diesel soot on the transom with the ReJex.
I'm probably back in the Corrosion X product business to sell just to the Faithful and their friends....finally got the shipping issue solved. My pricing will be 25% off retail plus shipping, and a reasonable minimum per order will apply, say $50 or it ain't worth fooling with. Like Dr. Matt with the lures, not in it for the $, but with those dreaded 8V92s, he needs money mo' than me.
I tried that the first year I owned Windstar and it didn't help.ianupton wrote:If you seal the top and bottom of the rubrail with sikaflex or something similiar wouldn't this make the problem go away?
Ian.
Harv
on a slightly related topic .....i sprayed max wax on all my running gear...all you can see is the stainless trim tabs...first they developed a milky coating and within a week it peeled off...so i thought thats that....however as i was asked a few times at the rendezvous........."how come theres no growth on your shiny bare metel trim tabs ?"
I recently sanded and polished my old aluminum rub rails and I was surprised on how they came out compared to what they looked like before. It took allot of sanding. I started with 100grt and worked my way up to 1500grt. I was thinking of adding a little 5200 on the upper and lower edges on the install to keep water from coming into the hull joints. Does that sound okay or should I try another method.
I should have probably went with the rubber rub rails but I am way over budget on this project already and had the time on my hands to do the work.
this is before
After
![Image](http://i194.photobucket.com/albums/z256/renegademike/newpics7-9-07052.jpg)
this is before
![Image](http://i194.photobucket.com/albums/z256/renegademike/newpics7-9-07042.jpg)
After
![Image](http://i194.photobucket.com/albums/z256/renegademike/newpics7-9-07051.jpg)
Yea the bow looks the same as the corners. It was allot of work. Iam guessing around 50 hrs plus.
I am about to install my side aluminum framed windows and was going to use 5200. Should I use the sikaflex 292 on that also?
I'm in Mexico so I have to see if the sikaflex 292 is even avialiable here. If not I have contacts in San Diego.
I'm in the process of putting a shit load of the boat restoration pics in photo bucket if anybody is interested in taking a look. Its under renegademike. Thanks for the advice, I can sure use it
Users browsing this forum: Bing [Bot], John Nardi and 481 guests
