I noticed my starboard engine was smoking and leaving a nice soot layer on the transom after running. The engine ran fine and turned up full RPM so I pulled the injectors and figured it out. After testing the injectors # 2 injector wasn't popping just sending out a mist of diesel and dripping after it fires. #3 went off at 200psi with a nice atimized spray but had a slight drip after fireing. Action Diesel in Ft Pierce is rebulding the injectors for $40 a piece and a new tip for the # 2 injector is $42 bucks so for some short money and some of my free labor we should be smoke free once again.
RussP
diesel smoking.
diesel smoking.
KAHUNA 1963 Sportfish
Scot, here's the drill - this is for a 5.9 liter Cummins 6BTA, so adjust for your displacement: take a 16 oz. plastic trigger bottle and put 8 oz. of distilled water in it, then one oz. of the blue Dawn liquid dishwashing detergent and swirl it around to mix, don't shake and make bubbles. Take the air cleaner off the engine and run the boat up to cruise load underway, not out of gear at the dock...let it heat up to full operating temp, then shoot the 9 oz of Dawn/distilled water into the air intake over about a 3 minute span...use a stream rather than a mist. Then follow with 6 oz. of pure distilled water from another pump bottle. And that's it.
I bought a couple of 32 oz. pump bottles at Wally World and mixed enough Dawn/water to do both engines and used the other for the distilled water follow up. Diesel upkeep on the cheap....no, it does not hurt the engine.....your diesel at cruise ingests a few gallons of water per hour at 50% humidity, just think about it...the Dawn does the trick.
Users browsing this forum: Google [Bot] and 79 guests
