Ok guy's...what's the group's pick for engine mounts, R&D?
It's a heavy engine/gear (2,300 lbs) and I will need 4.
Bruce's shots of self destructing Yanmar mounts will certainly make you think twice about installing el-cheapos.
Engine Mounts???
Engine Mounts???
That's something I had not considered, but I'm sure I can "guestimate"....or do what I typically do any way, buy one size bigger than the chart shows I need.You need to know the weight front to weight rear to make sure that you don't need different load mounts front and rear.
I'm not any good at building light & fast....I'm much better at building slow, heavy & bullet proof.
thanks..
Thats my trade mark also.......but I rarely have to apologize for my work other than because it weighs a ton
I figure that if a little paint does a little good just think what a lot of paint will do...Ha
Harry Babb
Harry Babb
I have had acouple of people tell me that I should NOT use the gear for the aft mount on my heavy engine. I ran across this 6V71 Detroit in a bone yard in South Louisiana. This engine has the aft mounts coming off the rear housing of the engine.
My engine does have this same rear housing...should I go this route?
Users browsing this forum: Google [Bot] and 127 guests
