has any of the faithfuls installed the spary rails or smart rails on there 31 b's ?if so i would like to see the finished pistures if possible ...what kind and how did you attach-em???? and how much did they really help ??? thanks
phil
spray rails
Spray rails
Take a look here, these are very common in Florida. Taco Marine part number V21-0824
http://www.tacomarine.com/item--2-1-16- ... -0874.html
if the link doesn't work go to:
www.tacomarine.com and use the search box for: spray rail
Good stuff
Steve Moyer
Soundown Ft. Luaderdale
Good stuff
Steve Moyer
spray rails
thats the answer that i was looking for they look like they don't belong on a 31 bertram RIGHT??? well thanks for the answer to my question ,,,,
phil
phil
- Capt. Mike Holmes
Spray rails
Phil, I ran a 31 years ago that had large wooden spray rails, They weren't real pretty, but they did help - as we found out on the first trip after the owner removed them. John Cranston's spray rails are so big they almost act as an extended planing surface - they are pretty much a chine extension, if I remember correctly - and I understand they also do a good job at knocking down spray.
Personal choice here, does the boat being occasionally wet bother you a lot?
Users browsing this forum: Google [Bot] and 470 guests
