An Amazing B20 Barron
Here is a link to one of the most amazing B20 re-fits yet.
http://simplifying.net/phpbb/viewtopic.php?t=239
RussP
RussP
KAHUNA 1963 Sportfish
Rawleigh, the Barons had foam in the floor. If the foam is saturated, the boat will weigh 4,000 to 4,500 lbs instead of 3,000 and no amount of power will make her fast. If you can, take the boat to a truck scale and weigh it. The trailer will weigh around 1,000 lbs. I paid $7,650 for one with no power and foam problems, but that included a very nice trailer. I think a running one with no foam is probably a $20,000 boat. I'm in to mine for about $50,000, so it is cheaper to buy a good one then restore a bad one, having said that I got exactly what I wanted and nicer than any new 20' boat on the market for less money.
- chris pague
20 Baron
Rawleigh; Did you and your buddy look at the Baron? What did you find?
Chris
Chris
Nothing yet. We went and looked at it, but he would not say what he would take for it if the auction didn't meet reserve. He thinks he has a gold mine. He is a marine engineer! Need I say more. Strange fellow. Says he will redo it himself if it doesn't sell. It needs $10,000 to $20,000 spent on it at least. The engine is shot. It has a TRS drive on it which means it has a velvet drive on the big block. He cut the strap in front of the engine hatches to get it in. The transom cutout for te TRS is larger than the cutout for the Bravo, etc, so a structural transom rework would be required. It needs a small block with a dual prop outdrive. Also the tank has had ethanol in it, so it needs to be yanked. We will see if he comes back to us, but we are inclined to wait for the next one.
Good discipline Rawleigh, I bet it also has wet foam and minor transom issues. Upholstry is shot, there is never less than meets the eye on a project. That said, the Baron is a pretty fun boat. If it runs, run it 'till you need to fix it.
I hate auctions with reserve and no Buy it Now. Don't drink and bid or you may end up owning an old Buick because you were curious about the reserve...
Users browsing this forum: No registered users and 327 guests
