prop size
Gas or diesel?
You are in a tuff part of the world to talk to find a good wheel shop....but your fuel is almost free. What's fuel selling it for now, 12 cents a gallon?
Try this site: http://www.boatdiesel.com
use the "Prop Calculator" function....it will get you close.
I don't know if you have to buy the $25 membership to use that function...but it's worth it if you do.
Good Luck,
Good Luck,
Carlos- I don't know if this helps but I have an older Sportsfisherman with a heavy teak deck, gin pole, Radar arch, full encloaure and big chair. I'm powered with twin 210 hp Cummins 6bt's and twin discs with 1:50 transmissions. My props are 20' x 20" cupped 3 bladed Nibrals and I cruise at 21-22 kts. Cruise on Cummins 6bt's is 2400 rpm. WOT is 2650. I'm sure the other faithful will chime in with good advice. Walter
thanksscot wrote:Gas or diesel?
Good Luck,
that is true a gallon of gas is about 7 cents of $ but i would like to pay a lot more and have Chavez out
thanks for the link
- Capt. Mike Holmes
Changing engines?
Carlos, did you finally decide to replace the 453's?
Carlos - was that your B31 that got burned in the riot and was for sale on yacht world? Thought about you.
My private email is royvictor@cox.net.
Uncle Vic
Uncle Vic
Users browsing this forum: Google [Bot] and 69 guests
