Engine rotation
Engine rotation
This is probably a stupid question.....but what the heck
What is the rotation direction for port and starbaord engines? Have had my raw water pumps out for a while, and don't want to guess on installing the impellers. Yes, could kick em over and watch...but I would ; like to get everything hooked up in advance.
Giff
They will flip over the right way on the first or second rev every time, don't worry about installing them "in the correct direction". Use Pam or Dawn as a lube unless you are using the Tony Athens aftermarket ones, they can take oil, so use CX on them. And put some Tef Gel on the shaft. A little care now vs. a pain in the butt later.
Too hot here in coonassland to do anything but hang out by the a/c. 97 and the heat index is 112........time for a clear.
Thanks guys, appreciate the advice. Have Cummins 504's. What clued me in on the rotation was that the pumps were hooked up oppositely. Orginally I thought the rotation direction was handled by the transmissions, as my parents boat has virtually the same transmissions, with both enginges rotation the same and rotation direction handled by the tranny (coincidently manufactured in the late 80's vs early 70's for mine). Trannys are borg warner.
Lighting them off this weekend for the first time in nearly 3 years!
Giff
Users browsing this forum: No registered users and 296 guests
