Hi Bruce,
If you could help me with these questions, I would very much appreciate it. The three engines I am considering for my very light Bahia Mar are 240 & 315 Yanmars and Model 256 Steyr. What brand of transmission and what gear ratio should I go with on each motor?
I am getting ready to pull the trigger on a new pair and I want to have all my ducks in a row.
Thanks again for your help John
Gear Ratio ? for Bruce
- JohnCranston
- Capt. Mike Holmes
Gear ratio?
John, I think most of the high rpm diesels like the ones you listed use 2:1 gears in a 31 Bert application. I've mentioned I'm happy with the 1.91:1 Twin Disc 5011A gears I have now, although I had troubles with the 1.45:1 ratio in the same gear. I'm sure either a ZF or TD will work for you, the 5011A TD is probably smaller and lighter.
- JohnCranston
Users browsing this forum: Google [Bot] and 99 guests
