Any reasoable reason I can't put the 8D's under the cabin floor? Trying to move weight forward and this would help.
Thanks, Guys . . . you too Timmy
Battery placement
Battery placement
- Capt. Mike Holmes
Batts
Depends on how hard it is to get your cabin sole out for access, first. Mine is a bit difficult. Wouldn't want to need to get in there offshore with a boatload of people. Also, there are ventillation considerations, and potential height of water in the bilge to ponder. When mine was gas, I had the batts under the aft dinette seat on the port side, but two 8D's on the same side would lean the boat to port. I started with 4D's, no real need for 8's. Now I have two group 27 batteries on each engine, mounted under the cockpit sole between the engines. Easy access, vents good, got them on a platform up out of the bilge. The lighter batteries are about all my back can handle. although I've thought of going back to 4D's.
When we repowered we moved batteries from under the cabin sole floor to a shelf high under aft deck outboard of the fuel tank. Where they were was damp, sweating under there, were subject to a lot of movement in a head sea plus were low (ish) in the bilge.
Interested to know why you are wanting to move fixed weight forward, I thought with deep-vees it was the other way round.
Nic
Nic
Nic,
Since repower and bigger fuel tank she sits even more bow proud than usual (expresses do that). The chine at the stern is about 1 1/2" under water. She starting to have that hiena look, ala 28's. Not cool. Ain't never been accused of draggin ass, don't want to start here. If I bring the bow down and the stern up she will ride a bit better.
Bruce,
If I use the glass mat bats will I solve the off gassing?
If Bruce says yes to the previous question how much more are those than the wet cells? How much better are they?
Tanks, Gang
Bruce,
Tanks, Gang
Mikey: I've had a pair of AGM Orbital batteries in my boat for six years. They are still going strong. They are sealed and do nor offgas. Of gassing of lead acid batteries because of a charger problem is what corroded all of the hardware in my cabin (even with the batteries betwen the engines). I'll never go back! Price wise they are about double the cost. Be sure to get the Deepcycle/Starting ones and a charger that has an AGM setting.
Users browsing this forum: Google [Bot] and 49 guests
