The hynautic 50 went down in a high speed stbd turn coming thru some rough white water in Jones Inlet, Long Island. I could feel the pressure on the system and then I felt a pop and then nothing. Pumping the system back up to 25 lbs dockside, it went down to zero in an hour. The fluids' in the bilge.
Where should I start to look? There is a second helm on the tower.
P.S. For the steering fluid West Marine gets 14.99US for a quart; the auto store 4.95US(Dextron ll or lll).
Steering failure.
- Capt Dick Dean
Steering failure.
A/K/A El Gaupo
Dick, I would start by checking the piston seals then the fittings. You may need someone to turn the wheel to find the leak. If all fittings and piston look good start looking at any possiable areas where the lines may be chaffed. I'm assuming you have plastic lines not the old copper tubing.
RussP
RussP
KAHUNA 1963 Sportfish
- Doug Crowther
Users browsing this forum: Bing [Bot], Google [Bot] and 290 guests
