Nanni diesels in a 31b
I as helping Tow W. with his newest crab boat. I noticed a 31 nearby and walked. The sucker has two beautiful 320 HP Nanni's. The guy cut the stringers down and the engines are a very clean fit. I was surprised just how clean it was. One interesting thing about the Nanni's is they are designed with almost no hoses. Looks clean; only time will tell how they hold up; but I would say yanmar has got a competitor.
Time will tell if they are worth fooling with. When I got my little Vulva 4 banger diesels for the B25 in 1984 I was also impressed they had virtually no hoses, all metal pipes. Those pipes drove me crazy, cracking, the O rings failed all the time, hoses are a helluva lot better, absorb the vibration.
I notice that my Cummins 6BTAs have a short section of hose wherever a pipe ends and goes to another pipe...shock absorber.
We are having a major T-storm system here right now, I see water creeping under the door of the shop, glad I'm on a stool.
Nanni
I hear you Uncle Vic. The engines look good; but. This guy used risers meant for IO's so he did not have to cut into the aft bulkhead. The IO's risers point straight down while the inboard boat engines were set-up for 45 degree angle.
- Capt. Mike Holmes
Nanni
I think it is Japanese humor. Much like the term Karioake originally meant "Car full of drunk tourists from Oklahoma", these engines were so named that when their owners passed slower boats - usually Detroit diesel powered - they could yell back in their wake, "Nanni, nanni, nanni!"
- Doug Crowther
now now.
No reason to bring GM/DD into a conversation about jap diesels.
These are the same blocks as Toyota sells Yanmar. The difference is that Nanni (think its a french co.) Uses the toyota block internal's- ie pistons.
The externals like heat exchangers etc are quite different. The Nanni uses a single zinc- I think someone said the yanmars have six or seven ?
It will be interesting to see how much traction Nanni gets. Like many industries- see that Yanmar is doing well and wants a piece of that market share worldwide. When Harv, John D, Capt Charlie and myself talked to the Nanni people at the boat show their sales pitch was that you can walk into any toyota dealership in the world and order a piston. What about a raw water pump or heat exchanger ? Wait for it to come from some frog ?
I grew up to be the person my parent's warned me about.
Mike?
...and from a fellow Texan
DD's just refuse to die....Stewart & Stevenson has a pile of them in Houston that the EPA "makes" them destroy because they simply will not go quietly into the night. LOL[/quote]
I guess you don't remember the Tortoise and the Hare story? They may be slower, but I bet no Nanni's will still be running strong in 2060." passed slower boats - usually Detroit diesel powered"
- Capt. Mike Holmes
DD's
Scot, Timmy wanted to stir stuff up. I have run 671's, 8V71's, 6V92's, and 8V92's, ridden on Hats with 12V's, almost ridden on a Cheoy Lee with 16V's. Good old engines. all - just not real fuel efficient by modern standards.
Right on all accounts! Key word "OLD" If I had the spare change laying around for a 330hp 6BTA that's what would be going in my B25....but I don't so I'll run the donor DD, could be worst, could have ended up with another gasser!
I do have a perfect running 6BTA 210hp 12 valve with the massive Bosch pump in my 97 truck with 245,000 miles on it. I should yank it out, go see your conversion buddy and scrap the truck out! Engine runs like the day I purchased the truck, oil stays clean. I hear that the 12 valves are good for over 300+hp in the conversions, same engine as the 6BTA marine units....basically.
Users browsing this forum: Google [Bot] and 30 guests
