Yanmar mixing elbows—whoof!!!
Amberjack
Post by Amberjack »
It’s been 22 years so I thought it was time to replace the exhaust mixing elbows on my Yanmar 6LP-STP’s. The estimate for parts came back at $1,250 per engine. $3,500 total for both engines including shipping and labor. Ouch! This mechanic has always been fair—not cheap but fair—so I don’t believe he is gouging me but this seems out of line. Has anyone on the forum replaced these elbows recently? I’d like to get some confirmation before moving ahead.
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
Re: Yanmar mixing elbows—whoof!!!
Doug
There is an outfit right in your areas that makes them out of Stainless for half the price.
https://hdimarine.net/product/jh-stainl ... ing-elbow/
My friend used them. They seem pretty solid. They get good reviews.
Post by Yannis »
Doug, can you send a picture?
Once your putting product into UPS it doesn't really matter all that much where the product is made.
In my area this is the place for upgraded stock and custom risers and elbows is: http://www.marinemanifoldcorp.com/
I was a happy customer for 20+ years, recommending to my friends and customers with no complaints...aside from price on the Copper risers for 440 gas motors, which faded after motor ran cooler and they they just lasted and lasted.
Tony's recommendation is closer, but offering an alternate option.
Never ran across them before. Looks like another good option.
Amberjack
Post by Amberjack »
Yannis-here are the images.
https://imgur.com/a/1cqhTSE
Beautiful condition, nice and clean. How could they ever be corroded on the inside!
Doug Pratt
FBC hull #315-820
Not the worst design for an elbow...if and when it leaks most of the water "should" make its was straight down avoiding the turbo. But when its attached to a pretty darn expensive turbo, attached to a really expensive motor "should" is not the most appropriate word I'd want to hear.
If the outside starts to leak, I can't imagine what the inside were the heat is would look like.
What I find crazy is the coin they get for these things. A cast iron gas exhaust elbow is a couple hundred, casting SS or alum is the same aside from material prices which isn't all that much different. Buck a pound for Steel, 3 for SS and maybe 4 for alum, crude bar stock prices...I'd guess less for ingot.
The Cummins stock elbows are just SS tube welded with a couple flanges...in bulk that stuff is cheap. Buying 2 of each paid more then I should, but way less then the 1200 for new at the time. SB Marine has my stock elbows for the 6BT at 3995...nuts. I think he's just pushing his product.
Amberjack
Post by Amberjack »
Tony, how recently did your friend order from them? I emailed yesterday and called today but no response to either yet. Marine Manifold Corp way out on your coast responded pretty quickly.
Doug Pratt
FBC hull #315-820
Post by Yannis »
Thank you Doug.
I have the 4 LHA's, I recently went through the ordeal with the turbos, so I'm kinda used to hearing exorbitant prices...
I will have to go down to the boat and see how similar these mixing elbows are to mine.
Then, I should ask around to see how much they sell for over here, not expecting them to be any significantly cheaper than what you quoted.
However, I will try to see if one could find used ones in good shape and their cost.
I'll do this exercise and come back to you.
PS: How do you know that they need replacement? How bad are they leaking? I suspect that you could take them to a technician who would pressurize them to see if there are any cracks, at least that's what I did with my turbos which are cast iron too. And then, see whether they are fixable. I remember my turbo guy told me that he carried out some metaloplastic surgery to one of my turbos that were corroded around the flange that meets the risers, for which he charged me, but the cost was logical.
I can’t say anything bad about about marine manifolds and I welded up my risers. All that said, I really like the idea of SS investment castings over a welded product.
Even the best welder doesn’t always get 100% penetration and that welding zone is more susceptible to corrosion. Investment castings also offer better surfaces too, aesthetics aside, rough finishes and cavities are the places corrosion start.
Amberjack wrote: Feb 21st, '25, 17:45 Tony, how recently did your friend order from them? I emailed yesterday and called today but no response to either yet. Marine Manifold Corp way out on your coast responded pretty quickly.
Doug
Two years ago, and he talked to them last summer because he had a diesel mechanic work on the boat and the guy was telling him they were shot. Fortunately they weren't the guy was pushing to build up the bill.
micky
Post by micky »
I bought a set for my 315's from HDI marine last year. I had them in 2 days and they are great.
S Ritzert
Post by S Ritzert »
I made my own dry exhaust up and over the engine, then made my own mixer.
AJ
I will not need my original mixers anymore if you want them. I did drill a hole in one mixer for an egt probe. I will attach some pictures here shortly of the mixers.
Karl
Ditto on the turbos, I dropped around 7-9k on turbos. that was painful
Amberjack
Post by Amberjack »
S Ritzert wrote: Feb 25th, '25, 10:45
AJ
Thank you, I will take them and make a donation to the Forum! Pictures of mine are posted above on this thread to see if they match.
Karl
I hope to avoid that!
Doug Pratt
FBC hull #315-820
S Ritzert
Post by S Ritzert »
my engines are 6LYA-STP. I don't know what, if any difference that makes on mixers. See if these will work for you if you want them.
Amberjack
Post by Amberjack »
Thank you for the pictures and for reaching out in the first place but we are not a match. I guess that would have been too easy. Back to looking at new.
HDI Marine must be doing something right, recommended by two members on the Forum and this morning Paul from Marine Manifold (the other one recommended on the Forum) in NY called me and suggested I get in touch with HDI Marine. All marine suppliers should be so helpful.
Doug Pratt
FBC hull #315-820
S Ritzert
Post by S Ritzert »
no worries man, sorry it didn't work out. Mine are not in great shape, but they may have got you a couple more years... kick the can
wlbsr
Post by wlbsr »
does anyone have any intel on Marine Manifold in NY? Tried to call them his morning and it was a recording to leave a message. I see early in this thread something similar. Thanks. Bill
Bill
BERG1474M74J-315
FYI- From earlier posts they spoke with Marine Manifold, it was HDI they did not connect with.
Amberjack
Post by Amberjack »
I called Marine Manifold in NY a couple weeks ago and also left a message. Two days later Paul called me back. Very nice guy and he recommended I reach out to HDI in WA who apparently specialize in this equipment. I did and they called me back a couple days later to confirm they had the parts I needed so I specified their mixing elbows to replace my aged out Yanmar elbows.
Those will be installed today and I’ll post images when done.
Doug Pratt
FBC hull #315-820
S Ritzert
Post by S Ritzert »
I left you a PM. I hadn't noticed yours until a few days after you sent it.
Amberjack
Post by Amberjack »
And finally here they are—my new investment cast stainless steel mixing elbows. Don’t look much different do they but my checkbook will tell! Thank you to both Tony and Carl for steering me in the direction of a better and less expensive alternative to the Yanmar replacement parts.
And an amusing story. When I told the mechanic I wanted to use HMI parts instead of Yanmar parts I got a skeptical “Well it’s your boat” but after the parts arrived and he got a look at them he couldn’t stop talking about how great they are. I also think he fell in love with the lady that runs the place along with her father.
Doug Pratt
FBC hull #315-820
Users browsing this forum: No registered users and 22 guests
