tear down finally begins
S Ritzert
Post by S Ritzert »
I finally got started on the tear down of Bucktail.
This will be the first week
S Ritzert
Re: tear down finally begins
Post by S Ritzert »
Week 2
Wow...alot of custom work was done to that boat.
Quick look prop pockets, pocket door, curved head enclosure, ceiling electronics, nasty shaft logs (or bad pics), relocated exhaust...
Yet...looks like it needed some work.
Has to be a story there...
That said, project seems to be moving along nicely.
Keep at it and keep up with the pics please, as if no pic, it didn't happen LOL
Whats the direction you looking to go, if I may ask?
S Ritzert
Post by S Ritzert »
yeah, a lot of custom work. It was refurbished by Cabrera in like 2000'ish, I can confirm that year later on. I will be the 4th owner on it. It only has 715 hours since refurbish. Cabrera used some wood that is rotten in it, I will be going back with coosa.
I have never seen bolt on shaft logs, I usually deal with brass logs that are glassed in. What's your thoughts on those. They are defiantly custom built, the welds on them are about a 4 on a scale of 1 to 10, 10 being the best
Let the fun begin.
I would change those over to fiberglass shaft logs.
https://bertram31.com/proj/tips/shaft_logs.htm
I am also surprised that Cabrera did not beef up the strut pads.
https://bertram31.com/proj/struts/strut_backing.htm
If the rudder shelf is wood, I would change that also.
https://bertram31.com/proj/tips/rudder_shelf.htm
When we did our rudder shelf, we used structural fiberglass u channel from McMaster-Carr. Built two supports at each end and glassed it all together.
We also used structural fiberglass in the companionway rather than the wood supports that were original.
My original shaft logs were Bolted on Bronze logs. They had a pair of thin bronze backing strips on outside that had some corrosion but the log itself was 100%. I was planning to use, but going from 1-1/4 shaft to 1-1/2 it left no wiggle room and glassed in fiberglass logs. In short...I believe bolt on logs are fine.
If you are asking my opinion of using the existing SS logs in the boat...
Yes I agree the welding looks to be a 3 or 4 on a scale of 1-10. I assume it was stick welded with lots of starts n stops not to overheat which can burn away the corrosion resistance. So I could give a pass on being ugly, if done right. I would however pull and inspect the underside of the logs looking for corrosion/pitting around the welds, gaps, corners and inside tube, were packing hose mounts to log anywhere water gets trapped when sitting. If they used 316L material and rod, didn't overheat and bonded they could be fine.
Silverton had a model ( 28' ?) with welded SS shaft logs made from thin 12ga sheet and thin SS tube. For a few years we made quite a few replacement logs as they started to corrode through in multiple spots. I think that s an example of done wrong.
S Ritzert
Post by S Ritzert »
Tony,
Yes, anything wood will be replaced with coosa, ie, rudder shelfs, the generator shelf (which I am considering relocating the generator), the battery shelf. When I refurbished my 28, I did the same thing per the instructions on here.
I plan on removing the rudder ports, struts, and shaft logs to inspect the glass thickness, and integrity of these items. I considered re-welding the logs via tig welding, and cleaning everything up, but I do like the idea of glass shaft logs. I will make that decision when I get closer to that time. I was planning on adding glass to the strut area if that area didn't meet my liking to beef that up. I cant tell you how many struts and rudders I've seen ripped off of boats from impacts, so I am a firm believer in having those areas beefed up.
I appreciate the thoughts and ideas! thanks fellas!
Tommy
Post by Tommy »
I visited on the Bucktail with the 2nd owner in Georgetown, SC, somewhere around 2005, and the boat was in excellent shape. As Carl commented, "there has to be a story there" as to how a boat that was customized and repowered so well could fall into a state of disrepair. With that said, as I get older (71 now) I realize I don't have the energy to stay on top of some of my maintenance responsibilities around home and boat.......
Tommy wrote: Sep 19th, '24, 10:58 With that said, as I get older (71 now) I realize I don't have the energy to stay on top of some of my maintenance responsibilities around home and boat.......
Looks like the home will have to go...
S Ritzert
Post by S Ritzert »
Tommy,
I have had a conversation with Mr. Clark. I actually found him through some research on this site. He told me he purchased it from the original owner, and it was the original owner that had the work done at Cabrera. If I remember correct, he said the original owner, who was a friend of his, never even took delivery of it from Cabrera. Mr. Clark is the one that took delivery from Cabrera. He actually mailed me what information he had left on the Bucktail. Super nice fella!
I have the logbooks and receipts of service performed from Mr. Clark. One thing I wish he would've done was to strip the bottom paint off at about the 5th coat. lol
I do have a question that maybe you can answer for me. When you go to wide open throttle, it takes a lot of time for the port engine to spool up. The props are monsters on it. I had them sent in and cut down and re-pitched. I purchased new turbos as well, they have eaten a lot of saltwater, and I redesigned the exhaust system. Have you taken a ride on the boat? Do you recall it being sluggish?
When we redid our shaft logs, we found the glass in that area to be on the thin side. It might be worth just going all the way if you find the same thing.
Tommy
Post by Tommy »
S. Ritzert (I never got your first name),
When I met with Jim in Georgetown it was to look at some plantations that he managed in the low country, so we spent most of our time riding in his truck. He took me to the dock to see Bucktail, but we did not take her out, so I cannot report on a sea trial. You are correct, Jim is a heck of a nice guy. Maybe the folks at Cabrera can shed some light on the history of the transaction. Keep us posted on your progress!
S Ritzert
Post by S Ritzert »
Sorry, first name is Shannon, I don't know why that doesn't show up.
I thought Cabrera was shut down. I'd love to get some info from them if they have it. I'd love to have the hull number on the boat if I can find it. I haven't crossed that road with Texas Parks and Wildlife yet. To get the boat titled in Texas, we have to do an etching of the HID and engine serial numbers.
Tommy
Post by Tommy »
Shannon, remind me the build year of Bucktail. I believe it was 1972 when the government required hull numbers to be applied on the transom just under the rub rail on the stbd side. Prior to that most hull #s were glassed into the hull under one of the v-berth hatches. Other places I've seen hull #s are beneath the galley sink on the stbd hull and on the inside of the transom down behind the steering gear (very hard to find). Good luck, and let us know if you stumble upon it.
S Ritzert
Post by S Ritzert »
1964. I've looked in the locations recommended from the forums. I've not been successful. I am hoping in the tear down, I will have some success
Amberjack
Post by Amberjack »
The hull number will be written on the underside of the cabin sole hatch covers. The hatch covers were apparently cut to fit rather than being jig or pattern cut. I still have mine and avoided painting the undersides for that reason.
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
Tommy
Post by Tommy »
They were built super strong in 1964 with an extra thick fiberglass layup, so you have a very sturdy boat! I had a 1962 model and later a 1972 model.
Based on Doug's knowledge of the earlier models, you miight not find the number anywhere on the existing boat. The cabin sole hatch might have been discarded during renovation, which could be a problem for your search.
Amberjack
Post by Amberjack »
As Tommy said scrape some of the paint off the inside of the transom about 10” inches above the keel. Mine (1969) are on a piece of paper glassed in there. If there is one you won’t hurt it by removing the paint.
Doug Pratt
FBC hull #315-820
S Ritzert
Post by S Ritzert »
Yeah, the cabin sole hatch was a piece of wolmanized plywood that I assume the previous owner made himself. He was in the middle of installing the bathroom/shower, and had a water tank in the bilge under the hatch.
I will check the transom above the keel though
Snipe
Post by Snipe »
Good luck with the rebuild she looks to be a great boat to start with. A lot of work already done some elbow grease should cleanup nice then make a punch list and get started. Keep the pictures coming we all like pictures.
Jason
S Ritzert
Post by S Ritzert »
Week 3 of teardown. I am close to grinding, so I probably won't post until grinding comes along and the weather is cooler. I hate grinding and sweating my ass off.
Wow. That teardown was quick.
They do come apart easily. Can't wait to see her finished.
Post by Pete Fallon »
Shannon,
On the 2nd to last photo of the teardown, in the V berth area. Look under the white painted surface on the port side V berth just forward of the cross brace for the V berth supports that Caberra installed, the paper tag should be about 6 to 10 inches in front of the cross brace, down about 6 inches, from the un-painted glass, use some paint stripper, the paper tag is glassed into the hull in this area. If not there, look under the support for the aft section of the cockpit sole on the centerline down about 8 to 12 inches. If the boat is older than November 1972 the HIN number is stamped into the starboard stern about an inch down from the rub rail. I surveyed over 50 Bertram 31's in 20 years as a SAMS Surveyor.
Pete Fallon 561-310-7179 Leave a message if I don't answer I don't hear very well even with sound all the way up.
Ditto what Pete said about the tag, except mine is aft of the cross brace, forward of the bulkhead by 1 foot or so.
S Ritzert
Post by S Ritzert »
Pete,
Around this area?
I will shoot you a text so you'll have my number. I have a ton of work that pays the bills to do today, I will try and have a look during the weekend. I've neglected my work load the past few weeks to work on personal stuff. I appreciate the info!!
My tag is about a foot or two aft of that spot Shannon
Shannon,
Carl is correct, the tag should be in the area that you circled, just aft of the cross brace. It's been 13 years since I sold the boat, my memory is not what it used to be.
MarkD
Post by MarkD »
Shannon:
I trust that stool is for a cold beer to sit and observe all the hard work? Project looks great!
Good to see Pete Fallon back in action!
Mark
S Ritzert
Post by S Ritzert »
It's like a treasure hunt at this point, lol. In order to check the other spots, it will take some actual grinding. It looks like Cabrera glassed in some wood in the center aft section to be able to screw to. I assume this isn't factory, and will have to be cut out. I may do some cutting and grinding tomorrow morning if it is cool out.
Mark,
The stool is for acrobatic work. I used it to stand on to reach all the wiring that overhead. My drink of choice was whiskey, and I promise that stool would not hold me up after a whiskey night. lol. I've actually been sober for 2 years and a few months. Unfortunately I am not one that understands moderation, I was always full bore, or nothing.
I think the wood is covering the molded chine to give a flat wall. My boat had the wood, but only glued in spots falling apart under the rug the last owner laid down. Remove the wood and you will have a void.
You are in the right area...keep going back
S Ritzert
Post by S Ritzert »
Week 4
S Ritzert
Post by S Ritzert »
Week 5. I may have more to add to these if I do any work tomorrow
JeremyD
Post by JeremyD »
I do like seeing all the tear down pictures and where things are placed. Appreciate you posting. I am going to attempt to tackle the interior of mine when the temperature cools a little
Amberjack
Post by Amberjack »
Great images, they give a glimpse of the understory of my boat. Thanks for posting them. It’s unnerving how many openings are in our hulls, some original build, some added by previous owners. Early on in my ownership I mapped all the openings I could locate, many disused and capped off, one with a hardware store copper pipe cap. When the hull was done a few years ago I showed the yard 3 unused openings to be removed and glassed over. The yard manager said why not plug them and just let them ride along and save $1500? I felt better filling and glassing them over.
Doug Pratt
FBC hull #315-820
S Ritzert
Post by S Ritzert »
No worries on the posting. My hope is that a good documentation will help someone out later on.
AJ, I will more than likely re-glass all the openings, and relocate where necessary. Some things I like, some things don't make sense to me. My thinking today is to put the generator down the middle of the boat between the engines. I have not measured water lines yet. We shall see on that.
I got a little done today. Tomorrow is actually the end of week 5. It is about time for me to start winterizing my clients boat, and I hope get prepared for that this week, and get started next week. That will keep me pretty busy until mid December. I don't know how much work I will get done during this time, but I will post pictures if I accomplish anything!!
Tommy
Post by Tommy »
Wow Shannon,
I had no idea that you were going to lift the bridge off the hull altogether; this gives a new meaning to the phrase "stripped down to the stringers"!
Like the others, I am grateful that you are going to the effort of posting progress pictures because it is providing a great education for us. I've owned three 31s and have crawled all over, under and through these great boats, but you are providing a view that I've never seen before. I wish you much success with your project!
wow...that is stripped down.
S Ritzert
Post by S Ritzert »
I have a little to update. We are wrapping up our winterizations for the year, and I am slowly finding time to work on the boat. I just completed lifting off the deck over the weekend. I figured yall may get a kick out of this.
When you say tear down, you really meant it!
S Ritzert
Post by S Ritzert »
its the snowball effect..... while I'm here, lol. The wood under the deck was rotten around the rod holders, and the bow has an incomplete repair from the wood under it rotting. Might as well get it fixed while I'm torn down this far. I told my son that he is getting this boat when I am gone. I don't want him to have to deal with anything more than maintenance, and a possible repower. Hopefully he takes me fishing when I am incapable of taking myself.
Wow. You had to build a false floor under it so it didn't crack on you. Nice very nice.
Ironworker
Post by Ironworker »
Reading this thread is causing me to have PTSD.
Rick Ott
Fly N Fish
1969 B31 Flybridge
Hull # Don't have a clue
S Ritzert
Post by S Ritzert »
LOL. Don't PTSD out on my now, this will go great.
I need to flip that deck to get to the underside, I've already tried once, and I am going to have to come up with another plan, it was flexing to much for my liking.
I do have a question maybe ya'll can answer for me. Is this an original deck with the "livewell", or is this possibly a Cabrera deck?
Ironworker
I did a couple of things to my deck which I left in place during the retrofit. I added a 1/2" piece of coosa under the gunnels and glassed it in to have a backing for my rod holders. I HST so this was critical. I then added two layers of glass to the top surfaces of the entire deck including the bow. This stiffened the entire deck and got rid of all the cracked gelcoat and glass from flexing over the years.
Rick Ott
Fly N Fish
1969 B31 Flybridge
S Ritzert
Post by S Ritzert »
I plan to cut out all of the wood, and was thinking 5 layers of glass.... Matt, Bi-ax, Matt, Bi-ax, then Matt. I was going to do coosa gussets for support (gunnel to hull), and running wires through. I debated doing rod holders, I have not made that decision yet.
Tommy
Post by Tommy »
Shannon, it's an original top-deck with an aftermarket livewell that was fabricated into it. The aftermarket livewell kit may have come from Cabrera.
S Ritzert
Post by S Ritzert »
Tommy,
Thanks. They did a good job putting that together
JeremyD
Post by JeremyD »
Tommy wrote: Dec 19th, '24, 15:29 Shannon, it's an original top-deck with an aftermarket livewell that was fabricated into it. The aftermarket livewell kit may have come from Cabrera.
Was thinking the same thing. I also cut out the wood from the underside and added a couple of layers of foam board and glassed and sandwhiched in 1708. Stiffened it up real good. Fein style multitool made it easy to pull the wood from the underside
Oldcreek
Post by Oldcreek »
Shannon, I recall that Bob H. pulled off his deck when he re-did his Bahia Mar if that’s any help for ideas.
The wood under my Bahia Mar gunnels are rotten, too, and I’ve been debating on pulling the deck… but I don’t think I could pull that off where I’m working on it.
Jeremy and Rick, did you find that working “upside down” glassing in the foam board/coosa to the gunnels with the deck in place very difficult? I have a lot to do!
Shannon, btw who are you using to host your images?
Wil M.
1969 B31 Bahia Mar w/ Factory Hardtop, #316-764
2014 G3 14'
S Ritzert
Post by S Ritzert »
Oldcreek wrote: Dec 19th, '24, 23:39 Shannon, I recall that Bob H. pulled off his deck when he re-did his Bahia Mar if that’s any help for ideas.
My arms won't let me work overhead much any more. With the vibration of the tools, and bad shoulders, there's no way I could be efficient in getting work done. The older I get, the more I learn its worth the time spent to make the hard work easier. I try to teach my guys that in the shop, but they're still young, and full of piss and vinegar. lol
I use imgar for picture hosting. I use the link section that allows the photos to be seen, instead of posting links you can click on. I think there's a tutorial in here to show you how to post photos. I am not a tech geek by any means, unless its boat, car, or engine related. I had my wife teach me how to post the photos, lol
Users browsing this forum: No registered users and 24 guests
