I am looking for a product that I can spray into a mould and lay up epoxy/fiberglass onto the sprayed in material so when I remove the piece from the mold, the sprayed in materiel would be the finished top coat. It would also have to be UV resistant. (The same way one would spray polyester gelcoat into a mold and lay up with polyester/fiberglass).
I can't seem to find a UV resistant epoxy based "gelcoat" material in the US. Any ideas?
Epoxy Gelcoat??
Re: Epoxy Gelcoat??
Use regular gelcoat, it’ll be fine with epoxy resin.
Re: Epoxy Gelcoat??
I'm a big fan of epoxy resin and fiberglass. I prefer paint over polyester gelcoat.
Rick Ott
Fly N Fish
1969 B31 Flybridge
Hull # Don't have a clue
Fly N Fish
1969 B31 Flybridge
Re: Epoxy Gelcoat??
Paint over epoxy yes
IN a mold gelcoat is what you want. You can then paint it or leave it in gelcoat when the part is out of the mold.
Re: Epoxy Gelcoat??
OK Thanks.
I'll experiment with gel coat and epoxy and see how it goes.
Re: Epoxy Gelcoat??
Marshall,
You may want to look into vinylester with gelcoat.
There are some really nice VE resins that perform similar to epoxies,
with compatible gel coats
Pete
Pete
1978 31 Sportfish
Secret Plan
Hull #1736
3208T's
Secret Plan
Hull #1736
3208T's
Users browsing this forum: Google [Bot] and 82 guests
