Wife and I are thinking about a 1 night get-away to Block Island either 7/1 or 7/2. Any suggestions as to lodging and restaurant? Thanks.
John F.
Block Island Suggestions
What kinds of places are you looking for? Swanky, basic, or somewhere in between? Email me at stevonbi@msn.com or give me a call
401-466-9725 H
401-487-2425 C
I'll be happy to steer you to the right place.
Steve
401-466-9725 H
401-487-2425 C
Steve
- Capt Dick Dean
Hynautic steering
The Hynautic steering went down last night travesing the Jones Inlet(NY) as I had to make a hard stbd turn. I felt some thing go( pressure resistance and then nothing) but where? This AM I pumped up the pressure from zero to 25 lbs. An hour later it was zero and looks like steering fluid in the bilge.
Where do I start to look> I will look for fluid draining to the bottom of the bilge and go from there? Or is there a weak link in the system?
A/K/A El Gaupo
Dick-first look for the obvious. Follow the lines. If you're using the red fluid it's easier to see. If a break/leak isn't obvious, refill, presurize and put paper towels under as much as you can reach/see and look for what you find in a few hours. Mine leaked at the underside of the steering arm piston in the stern. If that's the case, I would suggest calling Charman Enterprises at 1-800-247-6324, 1-800-647-8449. They're in Eaton, Indiana. I fedexed my piston to him on a Monday and had it rebuilt and back in my hands by Friday at a reasonable price. Unless you have a break in your line, that arm and your steering hubs are the two other places. A rare other thing to look at might be the two bleeder screws under the fluid container. If they vibrated loose, you could leak there, too. Walter
Users browsing this forum: Bing [Bot], Google [Bot] and 165 guests
