Replacement Seals for Engine Boxes and Deck Hatches
Hi Folks,
I'm looking for a source for the right material to replace the engine box and deck hatch seals on my 1986 28 Bahia Mar. They are both starting to give up the ghost and I'm having a devil of a time trying to locate a supplier of suitable replacement material. My apologies in advance if this has come up before but until the search feature comes back online I thought it would be OK to ask.
Ken
Babylon, NY
Ken
Babylon, NY
:shock: Rawleigh you never fail to amaze me...your data base for boat oriented, general marine stuff is unequaled.
Oh by the way, I order more giant erasers. They work so well that you hooked on them, and then it's gone....so you have to buy more. Why didn't I think of that.
I wonder, should I consider sealing the deck and engine hatches on my B28? I guess it would keep water out of the bilge, but then dirt would accumulate even faster in the recesses. Plus it might conceivably cut airflow to the engines. Possibly reduced engine noise is the only real advantage I'd be looking for, probably put this job pretty low on my list...
- Doug Crowther
- Hyena Love
Seals? What?
A proper B28 should display a definite rub mark on the rear lip of the engine hatch where the edge of the hatch cover has rubbed thru the gelcoat and into the fiberglass. Its that hint of green which is the true mark of a well loved Hyena.
While we are on the topic, the operator of said vessel should also be wearing sacrificial calf guards, constructed of duct tape, to avoid the bench seat "rash."
Steve,
Is there any clearance available at all between the engines and the hatches? The link below is for the product I'm going to test out. It is only 1/8 inch sheet thickness and the guy also carries it in 1/16 if you're REALLY tight. I figure for $20, it's hard to go wrong. Haven't received it yet so I can't tell you how it will work out or the impact it has on sound deadening. My Crusader 5.7 Liter EFIs aren't really that loud so sound insulation was not my reason for buying it.
Ken
http://cgi.ebay.com/ebaymotors/1-8-NEOP ... QQtcZphoto
Ken
Users browsing this forum: Google [Bot] and 58 guests
