Eta Beta
- franzmerenda
Eta Beta
Here we are...let the journey begin.
It will be a looooooong one!
Re: Eta Beta
Congratulations, this will be one of the best days ever...the other will be when you sell it. LOL
Seriously, she looks great! What are the particulars, what's the direction you intend? Use n tackle a project as you go or an all-out attack?
- franzmerenda
Re: Eta Beta
Thank you Carl!
"Eta Beta" is a gasser SportFish, with two 2015 6.2 MPI Mercruisers 320hp, with less than 200 hours.
I'm going for a "down to the stringers" project, including genset, air-conditioning/heating, head w/stall-shower.
My only doubt is if keeping the same configuration (my favorite) or adding a bulkhead between cockpit and cabin.
An EZ2CY enclosure would be fine; the lack of a true door the downside
francesco
Re: Eta Beta
Francesco,
How do you consider AC and heating without a bulkhead? Even a plastic partition wouldn't provide any insulation I think.
- franzmerenda
Re: Eta Beta
Yannis,
if enclosures are made using EZ2CY or SeaCrylic (which is the very same material marketed when EZ2CY patent expired), they're like plexiglass; coupling those materials with Stamoid and proper zippers, would make cabin sealed almost as fixtures grant.
These kind of enclosures have been used often on air-conditioned flybridges (as shown in the picture).
The tricky point is achieving a practical way-in/way-out, without a true door, while I don't like a hinged plexiglass door, as on "Legit II" (nice 31, with head positioned forward, on starboard side)
Re: Eta Beta
The sport fish model. Nice. Adding a full head should be interesting.
I assume there is a lower station that is coming out.
- franzmerenda
Re: Eta Beta
Tony,
I've been looking for some affordable 31, preferably a FBC, for a long time, while I've been thinking that SFs, beside the nice seamless between cockpit and cabin, meant lower stations.
The funny thing, is that the other 31 I've been dealing with, which is by the way a boat that was renowned to CaptPatrick, is an FBC with the lower station!
This make me incline to keep it, even though it will be quite hard to have both, full head and lower station, above all due I would like not shortening room, between dinette benches.
We use to say: " You can't have drunk wife, wine in the cask and bunch of grapes in the vineyard"
Re: Eta Beta
Remove the lower steering and go with an autopilot remote. Flip the engine controls upside down and mount to the overhead as in a commercial airliner. The engine controls should be right above the overhead forward and to the right, so it should be easy. Eliminate any lower helm seat and use that space for your other needs. You will rarely use the lower helm due to visibility limitations. When I do use it I just stand in the forwardcomp anion way.franzmerenda wrote: ↑Dec 21st, '23, 10:27
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
FBC hull #315-820
Re: Eta Beta
Doug is correct. Tough to see over the nose when you are running at planning speed. Can get a little nerve wracking.
- franzmerenda
Re: Eta Beta
...not to mention the lack of visibility, due to full head volume against front window.Tony Meola wrote: ↑Dec 21st, '23, 22:19 Doug is correct. Tough to see over the nose when you are running at planning speed. Can get a little nerve wracking.
It was kind of romantic saving the second wheel, also because it's the vintage large 6 spokes; but everybody is wisely suggesting me to get rid of lower station...
Re: Eta Beta
I have a 1980 31 Sportfish. Hull number 1700. It has the upper and lower helms and the original layout except for a clear 1/2” thick polycarbonate rear bulkhead that has a “real” door made of the same material. It even has the original Bertram door hardware. I bought the boat with it like that and I really do love it. As for the lower station, I never pilot from there except when trolling or otherwise tooling around slowly. That view over the bow is bad and I like to see what I’m going to run over when traveling at speed.
1980 31' Sportfish
Ascendant
BERG1801M79J-314
Ascendant
BERG1801M79J-314
- franzmerenda
Re: Eta Beta
...and the beat goes on...
I'll be chasing on internet to find some decent engine cover, to get rid of those scant grey pieces of plastic and some shining SS raisers/manifolds
Re: Eta Beta
I get nightmares from those pics........
- franzmerenda
Re: Eta Beta
Well, it seems this is the 861st 31 manufactured after hull #101, which is the first fiberglass hull made in 1961.
I'm quite confused when I read that production number is obtained subtracting 101 to glassed printed number.
IMHO #961 means this is the 861st fiberglass hull manufactured, assuming #101 was the first one
- franzmerenda
Re: Eta Beta
Well:
It seemed to me like an elephant pregnancy, but finally the frame came out from the mold.
It has been quite a journey, scanning, engineering, making math and putting the mold together, but it seems pretty like the frame that was made by Broadus Rose once, unfortunately not available anymore.
The costs for Hightide Marine assembled profiles or Lookout Frames Kit (the one installed on Bayliss 31), were too expensive, considering I had to add crate, shipping to Italy and Custom fees (all combined, something like 33% of the buying price [already expensive]) led me to consider making a mold here.
Next week we'll put the frame on the boat, in order to check if everything is fine and then we'll make the molds for curved glasses.
All clear surfaces are meant to be made out of 8mm (3.15 inches more or less) plexiglass, clear, dark and light blue-tinted, with silk-screen printing all around, like car glasses (white or black); the 2 front shields can be made out of glass, for wipers.
I'm going to put together all figures in order to get exact production costs; my aim wasn't, isn't and won't be, selling the frame and it's worthless I tell to all board Faithful, if anybody would be interested, mere production costs will be charged.
I asked to the Molder to quote me a safe wooden crate, while as far as shipping, since I'm buying tons of items for my boat overseas, I'm confident I may get some cheap quotation from my shipping Agent. Dunno how much may be charged, as far as custom fees are concerned.
What I like the most, is that from now onward, Shipyard can "LEASH HELL", since there will be no risk the flybridge may collapse onto the rest of the boat
[/url]
https://youtu.be/wiwhq655dLk?si=rooT1E_TXdNwtUa8
[/url]
Re: Eta Beta
Wow, looks amazing!
A thought on reducing crating and shipping cost may be to cut the two side sections at the pillars. They could easily be lined up and glassed on site, may even make for an easier install. Anyway, I'd be interested...only need the front section for my upper Express helm.
Re: Eta Beta
Windshield looks great. How did the boat run with the 6.2 small blocks?
Re: Eta Beta
If I remember correctly, the frame for each 31 seems to differ slightly, so I would think before ordering measurements would need to be taken.
I think they did a great job on the mold. The finished product should look great.
- franzmerenda
Re: Eta Beta
Carl,Carl wrote: ↑Sep 23rd, '24, 07:10 Wow, looks amazing!
I'm gonna ask both, the engineering staff and the molder, where it would be better cutting the frame.
Let me tell you, even it's not the case for Express windscreen, quite a few calculation were made to be more than comfortable with loading weight on frame structure, due to flybridge superstructure; beside that, after putting frame on the boat, it seemed like it has been there since ever.
I know that upper windscreen on the Express doesn't have the shape of the lower one, but I'm wondering if glassing labor would be worth shipping savings.
Just to give you an example,I paid some sixteen hundred USD for shipping the rub rail by sea from California (crate was thin but huge)!
Shure: volume is bigger this time (W.9ft-2in x H2ft-3in x D.4ft-11in - weight: 120lbs with plexiglass shields I guess).
Let me get the best quotation I may achieve from my shipping agent for an East Coast shipment.
- franzmerenda
Re: Eta Beta
Tony,Tony Meola wrote: ↑Sep 23rd, '24, 21:22 If I remember correctly, the frame for each 31 seems to differ slightly, so I would think before ordering measurements would need to be taken.
I will take measures of 2 further aluminum frames that have been dismounted from a FBC and a SportFish (as mine) by the Shipyard that made the nice blue 31 for the American Owner who kept the boat at Cinque Terre, in order to be sure figures match.
What I can tell you is that right side frame (not curved shield) is 2" shorter than left one: this will be my first investigation!
- franzmerenda
Re: Eta Beta
When I sailed the boat to the shipyard where I loaded her on the truck, she made 24ktns @ 3.300 RPM.trace elements wrote: ↑Sep 23rd, '24, 08:25 Windshield looks great. How did the boat run with the 6.2 small blocks?
Boat was empty and low fuel
- franzmerenda
Re: Eta Beta
Express upper windscreen Tony, as I could see from pictures, has a completely different shape from the original front frame...Tony Meola wrote: ↑Sep 23rd, '24, 21:22 ...I would think before ordering measurements would need to be taken.
Different from this one I mean
Re: Eta Beta
You make a good point, I have always taken it for granted the upper and lower frames and windows are the same...or close enough to be made to fit. I think its in order for me to go down to boat and jot down some measurements and compare.
In any case, the picture above is not an Express but a sedan, the helm is too far forward. The express has same FBC Cabin, but the helm is just aft the head...my steering wheel pump is just inside the head with controls above and just forward the bulkhead with me standing above motor.
Re: Eta Beta
Nevermind...no measurements needed...after 30 years I can clearly see the curved panels and frames on my helm are swept back further then the lower cabin windows. Funny...but having the front wrapped in canvas 99.9% of the time I never looked.
I guess I am a little happy as I had intended to order the plexiglass curved panels once or twice years ago when they were available, I even contemplated buying a set of old frames.
Re: Eta Beta
- franzmerenda
Re: Eta Beta
You're right Carl the picture with Dick Bertram was meant to show Tony that the frame of all models (FBC, SportFish, Open, Hardtop [or Sedan] and Express Cruiser as far as lower one) are exactly the same, while the upper window of your boat, has a different shape.Carl wrote: ↑Sep 24th, '24, 07:37 In any case, the picture above is not an Express but a sedan, the helm is too far forward. The express has same FBC Cabin, but the helm is just aft the head...my steering wheel pump is just inside the head with controls above and just forward the bulkhead with me standing above motor.
If you look at the picture here below, you'll notice that the lower one has a V shape in the center, the upper one a Lambda shape
Re: Eta Beta
Not sure why I thought that some didn't match up to others. I thought we had a discussion on this especially when purchasing the Fiberglass Insert to eliminate the front Windows.
In theory if the windows are all the same on the same models, then the Fiberglass insert should have been a perfect fit from boat to boat.
Re: Eta Beta
Francesco,
Crazy...30 years with the boat and I have seen that picture of Dick Bertram in the sedan a dozen times. Not once did it cross my mind the two sets of windshields were very different. Only this time, with some pointing out, thank you, I realized something was off. My helm windshield does not come down at that angle, maybe the sedan was different...nope...mine is.
The last picture was a Huh...how did I not see that.
- franzmerenda
Re: Eta Beta
Even the very Best sometimes forget that 'the devil is in the details'
Re: Eta Beta
Francesco
You did a great job with fiberglass windows !! I m really impressed!
Stavros
Athens
31 Sportfish Cummins QSB 305HP
Stavros
Athens
- franzmerenda
Re: Eta Beta
Good day to all Faithful:
Side windows frames glassed and primed, front windows frame glassed, half countertop on port side removed, bow deck stripped and ready for installing new hatch, anchor roller and everything else
Re: Eta Beta
Great progress Franz; keep up the good work.
I look forward to taking a ride on her with you at some point in the future!
Re: Eta Beta
Hey Francesco - wow!!! - this is my wife's late father's boat (and a lot of the reason I own a Bertram 25 now). I know the family you purchased her from, my wife's family also have a house on Santa Maria.
I've been out in Eta Beta a few times, what a boat but it was in dire need of a lot of work.
Dove fai i lavori? Olbia?
- franzmerenda
Re: Eta Beta
The charming ‘Ingardis’ are one of the nicest chapter of Eta Beta’s history and I just picked up the baton from Them!
The boat is now in Livorno and she’s undertaking an extensive restoration at CNC (Cantiere Navale Calambrone).
I’m really enjoying pampering her at my best!
- franzmerenda
Users browsing this forum: No registered users and 112 guests
