degree of deradrise
lobo
degree of deradrise
Post by lobo »
Hello all , does anyone know the degree of deadrise on our 31 bertrams ? I'm trying to purchase a transducer for a new unit . I think it's 21 degrees but not sure . Thank you in advance. Russ- Rascal
HotSpot
Re: degree of deradrise
Post by HotSpot »
https://www.bertram31.com/specs/index.html
This shows 24deg at the transom. I think it’s rather consistent through the entire length.
If you are going flush mount by Airmar, the 20-degree unit works. Mine is just off the center line in the area under the companion way. Actually, it is near the starboard engine stringer. If I measured it I bet it would be lined up with the midpoint of the engine.
lobo
Post by lobo »
Thank you, this helps greatly ! Happy Thanksgiving to all
Users browsing this forum: Bing [Bot], Google [Bot] and 71 guests
