A previous owner rigged Amberjack for commercial salmon trolling in the 1980’s. He did his own work and it was crude including the inside steering.
The steering station has been bugging me for the many years I’ve owned the boat and this winter I removed it. It was a chore and wound up being expensive but I think it was worth it.
I swear this was the last project!
The last project
The last project
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
FBC hull #315-820
Re: The last project
You left the lower controls in, was there a reason for that.
Did you do the glass work. She looks good and you are better off without that wheel in there.
Thanks Tony. The lower controls are disconnected but haven't been moved yet. My plan is to flip them upside down and mount them on the overhead. In retrospect it would have been a lot cheaper just to skip the AP and on the rare occasion run the boat from inside using engine controls only.
I did the glasswork such as it is. Used a drill to clean up the old screw holes, filled them with MarineTex white, sanded with 220-400-600, polished with light rubbing compound and then waxed. You can still see the old fastener wounds if you look for them.
Doug Pratt
FBC hull #315-820
FBC hull #315-820
Isn’t every project the Last Project till the next project?
Looks great! Can’t wait to see how the next project comes out…
Users browsing this forum: Bing [Bot], Sweetnut, Tommy and 409 guests
