BORG WARNER TRANS
Craig Mac
BORG WARNER TRANS
Post by Craig Mac »
I have a transmission leak in the back of the tranny-I think it is a rear seal--also have my deck out as I am replacing the tank. How difficult a job is it to replace the seal now that i have good accessability?
Any special tools needed?
Charlie J
Post by Charlie J »
easy take it out and have it rebilt, i belive theres a place in farmingdale every one uses
Craig,
If you can slide the shaft back to get a socket and ratchet on, you can remove the output flange. You will have to make a tool to hold the flange by the bolt holes.
Replace the seal and the crush sleeve and torque to specs.
daydreams
Post by daydreams »
I just changed my rear seal, took about 3 hours. Make sure you have enough room when you slide the shaft back . I had to use a socket and pipe wrenches, the ratchet would not fit. Good luck.
Craig Mac
Post by Craig Mac »
Transmission is out and at the shop.
At this time was thinking of replacing rear motor mounts--any suggestions for new ones?
Users browsing this forum: Google [Bot] and 56 guests
