Tracing circuits
Tracing circuits
Any recommendations for a tool to trace some of the circuits in my electrical system?
Two problems that I am working on right now:
- When I replaced my aft bilge pump last summer, I found four wires feeding the old one. I figured out that one a direct feed (fused) from the battery and one was a ground. Based on the way the old pump had been wired, the third one appeared to be intended for running the pump manually. Since that feature does not work now, would like to find a tool which will allow me to trace that wire to see where it comes out.
- The navigation and instrument light switches on my upper helm station do not work. I have to use the switch at the lower helm to turn on the navigation lights. Once the navigation lights are on, I can turn on the instrument lights on the upper helm by turning on the navigation light switch and the instrument light switch. Again, I am hoping that a circuit tracer would be able to show me where the problem is.
Peter Schauss
Water-Lou
Water-Lou
Re: Tracing circuits
Do you have a bilge pump switch in the cabin. It should be on automatic, off and then on manual.
I will not be able to look until next week, but I may have the wiring diagram that you need.
Sometimes instead of tracing you might be better just taking them out and rewiring them.
https://www.powerprobe.com/na/en/produc ... fFA61E15eF
I was a mechanic in a previous life.
One of the main tools i used for electrical is a power probe.
To this day i carry one in my truck and boat. I consider it part of my, "if i break down i need this" kit.
The tool i think you're asking about is their circuit tracer.
They're pretty expensive, but if you're familiar with the frustration and time required to chase old boat wiring, you'll feel it paid for itself the first time you use it.
The power probe is like a test light, except when you touch a circuit, it tells you if you're touching power, ground, or open.
Then, you can apply a ground or power to whatever you're poking with it.
Good luck
Good luck
Todd
Todd,
That looks like the tool that I need and the price is reasonable when I consider the time it will save me.
Tony,
My boat does have the original Rule manual/ automatic bilge pump switch. I found that it has power to it but it does not activate either pump.
The previous owner’s mechanic seems to have replaced it with a push-pull switch which allows manual operation of toward pump. For normal operation, both pumps are wired, with fuses, directly to one of the batteries.
Tony,
Peter Schauss
Water-Lou
Water-Lou
i second the power probe have one in the shop and one on both my boats
I typically use a multi-meter and an extra long lead and do continuity tests, I am pretty good with that setup and would like to understand the additional value of the powerprobe.
does the power probe send a signal on the line and the receiver allow you to touch the outside of a jacketed wire to determine if that signal is on that line?
You can use a power probe, a multimeter set on continuity scale or a tone generator.
I have all three and have been using them forever. I find they fit different issues.
A set of MAc tools retractable test leads 2x30' are another invaluable tool in electrical work.
I have found in old boats with old wiring its not uncommon to have wires cut or corroded somewhere not easily seen.
And out of the three above I use my Triplett meter by far the most.
My two models of power probe do not act as a tone generator. But you can pick one up for under 50 bucks.
You can use puncture probes for testing wires. It puts a pin probe thru the insulation rather than cut the insulation. Usually the insulation just closes over but one can use liquid electric tape to seal the puncture if they like.
I use these on the power probe or the multi meter.
Safety related stuff like bilge pumps and float switches should be periodically replaced. I check mine a couple of times a year and replace them every 5 years working or not.
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
Users browsing this forum: No registered users and 298 guests
