For those of you targeting larger fish, what have you done in terms of gunwale modification/reinforcement? I stuck a few bent butt rods into our existing rod holders and am a little freaked out by how much the gunwale is flexing when I push on the rod. The amount of pressure a fish applies is going to be much stronger.
I bought a swivel rod holder with a backing plate that I plan to install in the next day or two; the backing plate is only about the size of the rod holder plate on top thought.
Is additional fiberglass reinforcement something you've done before applying that kind of pressure?
Rod Holders & Backing Plates for Bluefin Tuna
Re: Rod Holders & Backing Plates for Bluefin Tuna
I haven't put them to test but here's what I've got, 30 degree forward angled out, 15 aft, 0 degree swivels on transom all lees HD with the deeper mount
https://photos.app.goo.gl/zrF8U5KwyR2XMzp86
I fitted and epoxy'd in 3/4" Marine ply under the top cap, and will be through bolted - here's a core cut out pic
https://photos.app.goo.gl/BfKpJaUNffGpjMzy8
That makes sense. How big is the piece of plywood underneath?
Max
the backing pieces fully fill up under the gunnel, here's a pic of the stern when I was building the motorwell. I don't have pics of the side gunnels but those pieces have a similar setup except that I didn't fill up the raised portion with strips of fiberglass, I just used excess filler.
https://photos.app.goo.gl/ttVwWwqFUjg2BFBg8
I did something similar except I used 1/2" coosa. I glassed both sides of the coosa then used a layer of glass to laminate it under the gunnel. I'm using stainless backing plates behind all of that.
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
I believe Capt. Pat had said that when he reinforced the transom gunnel for rod holders he ran the backing plate from corner to corner.
Users browsing this forum: Bing [Bot], Google [Bot] and 314 guests
