What is this?
HotSpot
What is this?
Post by HotSpot »
Every season, I come across one or two of these down near the drain plug.
I have yet to see one connected to anything. Where the heck are all these coming from? The bend makes it look like some kind of clamp. The look of it seems to indicate it is very old maybe original to the boat. Wiring clamps? Old rub rail fittings? Anyone know what these are?
scenarioL113
Re: What is this?
Post by scenarioL113 »
It is def a very old looking screw. If you keep coming across them then maybe one day the floor may drop or something....LOL
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
Re: What is this?
Post by Yannis »
Looks like a sacrificial anode for a curved surface; on a tube? on an exhaust?
Unless it's a bronze thing with salt...in which case science has no answer as of yet!!
HotSpot
Re: What is this?
Post by HotSpot »
Shined right up. bronze. There are some marks on the back that make it look like it was clamped to something metallic.
Maybe the Scenario's deck theory is close to being correct. :o
Raybo Marine NY
Re: What is this?
Post by Raybo Marine NY »
seems to be a saddle washer, where it was clamped to I cant help you with that
ktm_2000
Re: What is this?
Post by ktm_2000 »
I have the rear hawse pipes out of my boat when I went to gelcoat the gunnels, that piece looks a lot like the clamp which holds them down from the underside
Raybo Marine NY
Re: What is this?
ktm_2000 wrote: Jun 1st, '22, 12:37 I have the rear hawse pipes out of my boat when I went to gelcoat the gunnels, that piece looks a lot like the clamp which holds them down from the underside
this would make sense!
HotSpot
Re: What is this?
Post by HotSpot »
You are on to something. I noticed that the port side corner hawse pipe was completely loose at the end of last season. Just held in by gravity. I assumed it was an adhesive failure and was ready to break out the caulk gun. If this is it, the other one is probably loose too or just hanging on by a couple threads. I’ll check it out when I get back to the boat. Thanks!
scot
Re: What is this?
Post by scot »
Hawse pipe retainers 👍
HotSpot
Re: What is this?
Post by HotSpot »
Hawse pipe clamps indeed!
Of the six total clamps, I had collected 5 over the years, and thankfully held on to them. Only one was still in place.
Thanks for the help, guys!
Back where it belongs...
Re: What is this?
Locktite is your friend!
ktm_2000
Re: What is this?
Post by ktm_2000 »
I'm glad that I could help.
my favorite saying from one of my friends, "Every now and again, the sun shines on a Dog's Ass"
Users browsing this forum: Bing [Bot], Google [Bot] and 64 guests
