Hi All,
I purchased a new thru-hull scoop to feed my livewell / washdown pumps and remember back in the day that I had to trim it to length and don't remember which direction it faced.
How tight to filling all the threads on the seacock do I need to go when I trim it to length?
https://photos.app.goo.gl/AjsM5BfujNkXo3aP6
Which direction is best?
Thru-hull scoop facing front or back, trimming to size?
Re: Thru-hull scoop facing front or back, trimming to size?
Fwd, especially if you are using a centrifical type pump.
Depends on the thickness of your backing plate.
2 to 3 threads left on your thru hull before bottoming out is fine.
Users browsing this forum: No registered users and 57 guests
