DIY re Chroming--Bow Chock/Cowl Vents
jackryan
Post by jackryan »
I just saw an old thread that I started a few years ago about cowl vents--it made me think about the possibility of DIY re chroming. Has anyone tried this system to re chrome parts on their boat? I need to re chrome my bow chock and some cleats. Possibly the cowl vents. Any idea what the process would be to prep the parts to re chrome them? Would they need to be primed? The part that they re chrome in the video looks like it may have been prepped and primed with a black paint.
Here's a video that makes it look fairly easy:
https://www.youtube.com/watch?v=c9-wFTUhpT4
https://www.youtube.com/watch?v=KBtdU10PIcE
Raybo Marine NY
Re: DIY re Chroming--Bow Chock/Cowl Vents
Post by Raybo Marine NY »
you notice he started with a speed shape. When you paint speed shapes they are a real smooth fine plastic so when paint is applied it almost looks like you poured it out of the can. very smooth and deep looking
I did a black chrome years and years ago, it was a paint process you sprayed not a spray bottle
the single most important step for success was you needed a perfectly smooth black surface, the smoother and slicker the better otherwise it would just come out like gray looking
We also did some experimenting with powdercoat and the issue was the same- because the PC didnt leave a perfectly smooth finish any attempts to make a black chrome/candy effect were useless
so if you plan on doing your bow chock you will need to blast it lightly, high build primer it likely more than once, spray it black and have that paint come out like liquid acrylic, then you can do their chrome process
and after all that dont dare run your bow line through it or you will quickly erase all that work
It's paint, not chrome.
Your painting, not chroming.
Chrome is very hard and durable, paint is paint.
In the video the guy scratches the helmet easily with a screwdriver.
The prep was also made to look easy...somehow I believe the base finish dictates the end result.
Whatever...it does look great.
Users browsing this forum: Google [Bot] and 66 guests
