Decorative Bow Cleat required
Friends,
I am searching for a Decorative Bow Cleat, new or used good condition.
Application is a 1965 Bertram 20 Center Console (Outboard) we are updating/ restoring.
Currently there is a centered pop-up cleat in the forepeak area.
We would like to replace with something similar to link below (top two pics).
(Hightide does not have stock of this item)
http://www.hightidemarine.cc/adjusters.htm
Thank you in advance for any/ all suggestions
Re: Decorative Bow Cleat required
Joe
See if one of these work. Hopefully maybe someone who has redone their boat may have an original laying around.
https://www.boatoutfitters.com/hardware/cleats
https://suncorstainless.com/steel-produ ... ter-cleat/
I'm going to be removing my original Bow cleat from my 31 and replacing with bow roller.
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
Rick
You using the bow roller for a winch? If you put it on, if you could send me a picture, I would like to see how the boat looks with it on. I have been debating a winch and a pulpit just does not look right on our boats.
WILCO, I haven't bought the roller or anchor yet. There is a thread somewhere here on Bertram31 where some photos where posted. I'm going to center my roller so the bow ornament has got to go.Tony Meola wrote: ↑Feb 27th, '22, 22:59 Rick
Rick Ott
Carolina Reaper
Carolina Reaper
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
FBC hull #315-820
Doug,
What is that small second roller on top for?
It confines the ground tackle to the bow roller like the SS hoop you have on the front of yours. Mine being mounted further aft the chain and then the anchor stock can lift up against it when being raised or lowered. The roller allows them to roll rather than scrape. Your hoop is far enough forward that the uplift from the anchor stock occurs aft of it and the ground tackle doesn't bind against it.
Doug Pratt
FBC hull #315-820
FBC hull #315-820
Thanks.
So that roller, like my hoop, is to stop the anchor from jumping out and over the main roller during heavy weather, something that would be serious IF the anchor is not secured with a secondary rope or shackle or something. Or, jump out of its track when lifted, while the boat is at a different angle eg sideways.
I have a similar aluminum fortress anchor like you, as a second anchor, and I use it from the stern when I moor bow-in.
Very good anchor, bites so fast so well that sometimes I have a hard time to lift it up. That is why I want to install a winch on the rear deck somewhere so as to avoid breaking my back, however with covid and all that mess many projects stayed behind...
Doug
Is that a Good Winch? They are the ones I was talking too. He is local in NJ and has an excellent reputation. I was not crazy over his roller and was not sure of the look.
I personally like the look of a pulpit but not on our boats. It just does not fit the profile.
By the way, sorry for taking the thread off track, and thank you for the replies.
I agree Tony, this should be a separate topic.Tony Meola wrote: ↑Mar 1st, '22, 22:06 Doug
Doug Pratt
FBC hull #315-820
FBC hull #315-820
Users browsing this forum: Google [Bot] and 512 guests
