I'm installing a new radio and GPS on Saturday. I got a new butane-fueled soldering iron/torch, connectors, and shrink wrap. But I forget, do I use silver solder or rosin core solder?
Alex
Silver Solder or Rosin Core?
- Dave Kosh R.I.P.
Using 2%-4% silver solder will result in a much more durable connection in the marine environment. Silver solder has a slightly higher melting point . I have had poor results using regular lead rosin core. Silver solder also has a rosin core for cleaning as it melts for adhesion. Also using liquid flux as I do will result in a suburb connection, especially in larger stock work. Happy soldering and make sure you coat it with liquid tape or shrink tubing. Dave K
Keep Fishing...
Users browsing this forum: Bing [Bot], Google [Bot] and 325 guests
