Previously known as SS Minnow
- Rick Jester
Here is what she looked like in the advertisement on Craigslist.
Here is what she looks like now
Seems like it is crazy hot or raining everyday
Rick Jester
1966 25 Express Cruiser
Hull 978
Hull 978
- Rick Jester
Re: Previously known as SS Minnow
The first thing I did was to take the engines out and 1 of the outdrives the other was missing.
No Image of the engines. They were 120's. I then cut the keyhole larger to accept the newer style outdrive.
After cutting the keyholes larger I had a lot of water coming out of the cut It was then I noticed this.
It appears a thin piece of wood put into the layup and mostly rotted away.
Rick Jester
Hull 978
Hull 978
- Rick Jester
I peeled the inner skin off and the plywood looked to be in excellent condition.
I tried to dry the plywood with heat lamps
But was unsuccessful. Video link
https://photos.app.goo.gl/F1nxqv7phYHr3WjB7
Rick Jester
Hull 978
Hull 978
- Rick Jester
Could not find any pictures for this part
I replaced the transom plywood with Coosa Bluewater, 1708 and West System epoxy
I then went on to replace the gunnels and front deck with Coosa and epoxy. I cut off the top layer of fiberglass removed the balsa core and epoxied down Coosa. I then epoxied the old top layer back down and then a layer of 1708 on top.
Forgot to put plastic under the cinderblock here
I then faired the deck and primed it. Waiting for it to cool down and stop raining to finish painting
Rick Jester
Hull 978
Hull 978
- Rick Jester
I need to order a new fuel tank. But I have a problem. Not really a problem, but confusion. My current tank states it is 32 US Gallons. That appears to be rather small for this size boat. I spoke with someone and they said the Bertram 25 tank was around 80 gallons and Bertram wouldn't make a special size that small. I took measurements and I can put a 125-gallon tank in its place. The 125-gallon tank is about the same size as the 32-gallon tank. Do fiberglass tanks have large baffles in them?
Rick Jester
Hull 978
Hull 978
Rick
They have baffles but they would not be that big to shrink it down to 32 gallons. Bertram in the early days did make a add on tank that could be ordered and added later. An old friend of ours who had a 67 31, added a 50 gallon tank that was designed and sold by Bertram to fit between the engines.
I wonder if this was a second tank to increase range. Maybe the larger one went bad and they ripped it out and left this one in place.
For some reason I cannot get the pictures to open on my computer.
cant open the pics as well
- Rick Jester
I am still learning. I have google photos and I am using the BBcode link. Can everyone see this picture? Was anyone able to see the other photos? I can see them, but maybe it has something to do with permissions.
Rick Jester
Hull 978
Hull 978
Yes, this last picture of your 25 Express on blocks in your driveway looks great. I could not see any of the other pics. Thanks for sharing.
We replaced our fuel tank with one gallons be sure to put fills on both sides
Rick
I can see the last one, not the others.
I've had the best luck posting links to my google photos
in google, click sharing icon on the top area on the photo, it creates a link for anyone to access then come into this site and share as an insert url
Users browsing this forum: No registered users and 453 guests
