Perko Sea Strainer--Cork vs. Rubber Gaskets
jackryan
Post by jackryan »
I have the Perko 493-8 sea strainers with 1.5" hose that currently have rubber gaskets. I want to replace the gaskets in them, but am only able to find cork gaskets locally. Do you guys have an opinion on the cork vs. rubber gaskets for a sea strainer. It seems to me that a rubber gasket might last longer??
JR
Sheer Folly
Re: Perko Sea Strainer--Cork vs. Rubber Gaskets
Post by Sheer Folly »
I have cork on my 1988 Bertram33 FBC, engine and gen sea-strainers and they are original, if that tells you anything.
Preston Burrows
Post by Preston Burrows »
My experience with cork versus rubber gaskets on my engines' Perko raw water strainers is that the rubber type do last longer as they are more tolerant when the strainers are cleaned as they hold up better than cork when the strainer assembly is taken apart.
The cork gaskets usually disintegrate when the strainer is dis-assembled, coating them very liberally with 100% clear silicone on both sides helps me install them and keeps them together better if the strainers are dis-assembled for routine cleaning - but, more often than not, they usually have to be replaced with new if and when the strainers are dis-assembled.
So..........cork for infrequent maintenance, rubber for more frequent!
Preston Burrows
1976 B28 FBC
BERF1398M76J-285
jackryan
Post by jackryan »
Thanks, that's pretty much what I thought. I figured that cork would not hold up as well as rubber.
Ironworker
Post by Ironworker »
There is rubber then there is the plastic crap sold in China these days. They cheapen the products by not including the plasticizers and stabilizers.
Rick Ott
Fly N Fish
1969 B31 Flybridge
Hull # Don't have a clue
Amberjack
Post by Amberjack »
In my limited experience dealing with China they will do exactly what you tell them to do, no less and certainly not any more. If these came from China the US purchaser was either sloppy and didn't specify clearly what they wanted or was being cheap and went for the least expensive option.
Doug Pratt
Bertram 31 Amberjack
FBC hull #315-820
Users browsing this forum: No registered users and 18 guests
