general strut questions
Hey Guys, when reinstalling your struts. what is used to "bed" the strut when it makes contact with the hull? I've read some people use a premixed bedding compound from interlux, others say don't touch that stuff. The yahoo who installed them last said he used 5200, but it peeled right off. Always thought 5200 was a nightmare to remove. I built a wood mockup strut and will be dry fitting it as per capt pats instructions. I set it at 10 degrees since my engine beds are now new and i have a blank canvas to work with. if i can get it to fit right, this will put my prop about 2 inches from the hull vs the 5 inches it was and 5 degree's flatter. I'm sure ill be making another wood strut as I'm being a touch aggressive but im now enjoying the layout and fitting part to come.
- scenarioL113
Re: general strut questions
I dont think you can go wrong with 3m 4200. Nothing will leak with 4200 and it is advertised to be much less bond strength than 5200
I have used 4200 for many thru the hull type applications and have been happy. Just my opinion
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
4BT Cummins
I know I will start an huge discussion, but 5200 does not have a place on a boat. Why in the world would anyone want to make something permanent or close to permanent. If you need to use it because you are afraid something is going to come loose, then you did not install it correctly.
I would use either Life Caulk or as Frank said 4200.
so just 4200 the crap out of it? is there a trick to not getting it on the screws or does that help with making water tight?
I always put it around the screws to make them watertight. If your base is a good fit, just put the 4200 under it. If not, bed the strut in thickened epoxy first to fill any voids. Don't skimp on the release agent, or better yet, cover the strut flange with packing tape so it doesn't stick! Also don't forget to coat the bolts well. Tighten the bolts until you have the correct fit and let it set up good. Remove, clean bed with 4200 and install.
What Rawleigh said.
Users browsing this forum: Bing [Bot], Yannis and 45 guests
