Aft bilge pump
Aft bilge pump
I need to replace my aft bilge pump. What I have in there now is a Rule-Mate 1100 gph with a built-in float switch. The reviews for this model on the Jamestown Distributing website are universally terrible. What do you guys suggest?
Peter Schauss
Water-Lou
Water-Lou
Re: Aft bilge pump
Use these switches. This link takes you to their Tef-gel page. Click on the "Pump Switch" tab on left side of screen. These are the Ultra Pump Switches.
http://www.wolfwire.com/tefgel/frameset.htm
Then pick your choice of simple bilge pump (w/o built in switch).
Re: Aft bilge pump
Most of the time the problem is the switch goes bad. I have only had one pump actually go bad.
Re: Aft bilge pump
Mine has the built-in water level sensor and there is a short in the unit somewhere.
Peter Schauss
Water-Lou
Water-Lou
Re: Aft bilge pump
Good idea. I’ll try that the next time I’m down at my boat. The pump has three wires going up to the terminal block: black - ground, solid brown- to the float switch, and brown and white which probably bypasses the switch.
Peter Schauss
Water-Lou
Water-Lou
Re: Aft bilge pump
I've bought 4 of the Seaflo 2000 gph pumps and they work fine. I've only had them for about 6 months and I double up my pumps but for $49 for a 2000 gph pump, I can afford to double them up.
https://www.amazon.com/seaflo-12v-water ... water+pump
Rick Ott
Fly N Fish
1969 B31 Flybridge
Hull # Don't have a clue
Fly N Fish
1969 B31 Flybridge
Users browsing this forum: No registered users and 60 guests
