Helm parts have started to arrive
Snipe
Post by Snipe »
The control heads arrived from Rg Rollin Co.and my gauge panels showed up from Seaboard marine
I will be building my pod and laying out the helm in the coming weeks. The quality of the control heads is second to none very happy not cheap but I feel worth every penny.Image Image Image Image Image Image Image
Jason
Re: Helm parts have started to arrive
Let the fun begin!!! Nice looking stuff! The Sendure parts I just ordered are not quite as sexy as your parts!!
trace elements
Post by trace elements »
I'm very jealous. Did you get your motors from Seaboard Marine as well? Those controls look top-notch.
bob lico
Post by bob lico »
i believe i am a absolute expert on those controls after 20 years of ownership. there is really nothing you can explain to a person having the OEM. controls .you turn around when docking facing the stern and your natural standing with hands on your side falls on the levers.you will be able to back into any slip and miss a pole by a half inch off the corners of the transom gunwale every day of the week.
pschauss
Post by pschauss »
bob lico wrote: Apr 26th, '21, 16:11 i believe i am a absolute expert on those controls after 20 years of ownership. there is really nothing you can explain to a person having the OEM. controls .you turn around when docking facing the stern and your natural standing with hands on your side falls on the levers.you will be able to back into any slip and miss a pole by a half inch off the corners of the transom gunwale every day of the week.
Even in a 15 kt crosswind?
Peter Schauss
Water-Lou
scenarioL113
Post by scenarioL113 »
I love these projects, they are like big jigsaw puzzles.....except a lot more expensive :-D
1971 28 Bertram
4BT Cummins
9-11-01 NEVER FORGET
Snipe
Post by Snipe »
Trace I did not buy my engines from Seaboard but I have bought some parts from them they are very helpful!! I wanted the Sox digital package so I can get the nema 2000 connection and put my info on the garmin.plus I added a lot of extra alarms.
Jason
While I would normally say no way you are getting in easy with a 15 knot crosswind. But one day I saw someone do it. Actually it was the yard forman at the marina. He did it using the standard controls.
15 knot cross wind if you don't have any boats sticking out past the pilings in your marina. Lay your boat up against the pilings with the stern of your boat lined up with the piling for your slip. Wrap a line around the piling and then around the stern cleat, and then put the outboard engine in reverse and in she goes.
It is a two person job, but during impossible times you take impossible measures.
bob lico
Post by bob lico »
yes even in a 15 mph crosswind !!! there is a huge advantage over standard controls mainly looking over your shoulder while backing into a slip compare to standing up looking backward with the handle on the levers in your hand.i always go out in 15 mph to 50mph (gale warnings) to be alone fishing for bass . i keep the engine running with the bow into the wind while the men in the cockpit cast into the bunker pods.when i get back i have to dock in tremendous winds so i put the stern on the opposite pole in the slip to the wind and ROLL the stern into the slip .once you are past the two front poles you can keep her straight between the poles with a touch of each lever and huge rudders helping you.believe me phoenix came back from the ocean many a time with a audience at the dock. the main procedure is to use the padded front poles as a pivot point and hard on the opposite engine in reverse and the boat will walk around the pole until straight in the slip.
trace elements
Snipe, where did you get your engines?
Snipe
Post by Snipe »
Trace my engines are running takeouts that I have replaced lots of parts and painted.
Jason
trace elements
Nice! That's the way to do it.
Users browsing this forum: 1962 31, Bing [Bot], Ironworker and 52 guests
