Frame-less windows adhesive/sealant
What type of adhesive/sealant is used for installing the glass to the fiberglass frames?
Re: Frame-less windows adhesive/sealant
Nikkei
I believe Capt. Pat used sika flex. Let's see what others remember.
Sika flex,Bostic,or 3m all make a adhesive to install window glass. There is also an etching primer that you need to put on the edges where the adhesive will be.
Jason
SIKA FLEX
PRIMER 206 G+P
AKTIVATOR 100
AND 296 IS THE SEALANT
PRIMER 206 G+P
AKTIVATOR 100
Where can I buy
PRIMER 206 G+P
AKTIVATOR 100
296 SEALANT
PRIMER 206 G+P
AKTIVATOR 100
296 SEALANT
Users browsing this forum: Bing [Bot] and 45 guests
