Best place to mount the Trim Tab Pump/Reservoir?
Hey Guys....I have a Glastech Deck...Where is the recommended location to mount the Trim Tab Pump and Reservoir? Inside the Laz on the other side of Steering Reservoir location?? Thanks, John
Re: Best place to mount the Trim Tab Pump/Reservoir?
I have mine attached to a deck upright near back hatch.
It's out of the way, yet can see and fill if needed and it stays dry.
Thanks Carl so in the rear lazzarette area correct?
Yes, tucked under a bit so excess water from hatches does not land on it.
I think mine is in the same place. I believe my bracket is lift out so that you can move the unit out from under the deck to refill and service if necessary.
Users browsing this forum: Google [Bot] and 12 guests
