Check your fuel vents!
I was recently working on my B31 and needed to remove the fuel tank vent hose. I noticed some dead grass in the end of the hose. I started digging around in the end of the hose and removed a small palm full of dead grass and two dead or hibernating spiders. Apparently they had toted this grass into the vent to make a nest.
You may want to check yours!
Rick Ott
Carolina Reaper
Hull # Don't have a clue
Carolina Reaper
Re: Check your fuel vents!
Actually the vent itself should have a screen on it so this does not happen. I know mine does.
I thought mind did as well. Apparently the screen is long gone.
Rick Ott
Carolina Reaper
Carolina Reaper
Replace it. The screen also plays a role in stopping any flashback into the tank in case of fire, I believe.
Does anyone have a fuel vent they would recommend? A link would be greatly appreciated.
I have diesel engines.
Rick Ott
Carolina Reaper
Carolina Reaper
Thanks Mike. Most appreciated.
Rick Ott
Carolina Reaper
Carolina Reaper
I've had some similiar issues and found this interesting:
https://www.boatingmag.com/five-boat-fuel-vent-tips/
Users browsing this forum: Google [Bot] and 304 guests
