Ac code
Ac code
A buddy of mine is having an ac issue it’s a Marine Air unit and is showing a code -A08 looked on line but haven’t found any codes hopefully someone might have an owners manual or know where he can find the codes. Thank you all.
Re: Ac code
See if this link helps you out.
https://www.manualslib.com/manual/89274 ... tml#manual
I do not see any trouble codes. You might need to call Dometic.
Re: Ac code
The passport system has been designed so many times because of issues so knowing the version is helpful but Marine Airrr passport controls normally gave out fault codes as letters, not numbers like HPF or high pressure failure.
Webasto AC uses numbers and the A08 code is high pressure shut down of compressor. Usually means no cooling water, clogged filter or pump issue, clogged thru hull.
Users browsing this forum: Bing [Bot] and 156 guests
