I am getting some minor leaks or weeping around my fuel pickup plate when I have a full tank. Reviewed the pictures Pat posted month or so back. Couple questions.
First, is the plate attached to the top of the tank with simple bolts/nuts or is the under plate (inside the tank) threaded? What I am trying to figure out is how tough it is going to be to remove. Do I need to have a hand inside the tank to hold and catch the nuts, or is it merely bolts that thread into the plate in the tank?
Second, in replacing the gasket, what should I use for gasket material? Liquid permatex type stuff, or should I use a sheet of gasket material and cut out a gasket? If the later, what is the best type of material to use?
Many thanks in advance.
Fuel Pickup Plate Questions
Ernest,
There's a 1/4" bronze mating ring fiberglassed into the underside of the tank top. Tapped 1/4"x20...
From Napa, or other auo supply, get a sheet of cork gasket material for the new gasket. Use Permantex #2 on both sides. A hand held paper punch makes a good tool for punching out the holes. A piece of 1/4" steel tubing, a hammer, & a block of wood works too.
- Hyena Love
Thanks.
As part of our seemingly never ending shake down cruises on Sunday, I ended up filling the tank to the brim. Boat ran great.
Nothing like passing up a Blackfin 29/30 FBC (the Bert 31 knockoff) with 6BTA 210's on the way out the jetties (I was only doing 22 knots) or coming back in with the tide and wind at our back rolling at 26 knots (but except for full fuel, we were light, just me and the Warden and a picnic type cooler.)
Cleaned the boat up, backed into the slip, no sooner did the Warden says its bluewater time, and the bilge came on. Her next words were "Hey, whats that sheen?" Looked like about a quart or so of diesel in the bilge. Urgggggg.
Fun never stops. But, except for this issue, the "non-working" list is down to engine alarm panels, toilet (new pump needed plus wiring), fresh water system (new pump needed), stereo (needs install and wiring), and plumbing the saltwater washdown/livewell. Of course, then there is the "cosmetic" list.
Thanks again.
Thanks again.
Capt. Patrick,
I used the cork gasket material on mine, but did not use any permatex, the old gaskets did not show any kind of sealent used on them so I went back with none.
DQ
DQ
"IN GOD WE TRUST"
"IN GOD WE TRUST"
Users browsing this forum: No registered users and 29 guests
