Sealing Windows
Sealing Windows
Now that the rain is back in the PNW (wasn’t gone long). I am seeing some water drips from the window frame. It’s mostly but not limited to the area where the rear of the curved window stops and the side windows begin. What’s the preferred sealant for this? I was considering 4200 but maybe that’s too aggressive. Any suggestions?
Re: Sealing Windows
Most of the members use Silkaflex. 4200 is too aggressive. The issue is that due to all the twisting they will start to eventually leak again.
Re: Sealing Windows
I have been told that 4200 does not have good UV resilience and that 3M's 4000 is formulated with UV resistance. I believe there are similarly a multitude of Sikaflex compounds and believe they append the product number with "-UV" to indicate durability in sunlight.
Good luck,
Stephan
Good luck,
Stephan
Re: Sealing Windows
https://www.bostik.com/ Try this site I use this to direct glaze my windows in it’s a great product.
Jason
Re: Sealing Windows
Do you happen to recall which product you used?
I am tired of replacing the exterior rubber for my front windows. Now thinking i just need to find a good UV resistant glaze.
Mack
1973 B31 "MAKO"
1973 B31 "MAKO"
Re: Sealing Windows
What exactly do you guys mean when you say “glaze”. When I look it up it appears to be synonymous with “caulk” or sealant.
Users browsing this forum: No registered users and 299 guests
