replacing gauges
replacing gauges
FINALLY, FINALLY, FINALLY My 28 FB is running. It was a long road with replacing oil sending units, oil pressure switch, rebuild on starboard transmission just to pull it part way out to turn the transmission pump 180 degrees for counter rotation but both engines fire up and sound beautiful. Now I want my gauges to read correctly. Does anyone know if the water temperature gauges are different for dual station set-up?
Re: replacing gauges
If the gauges are identical, same make, temp range they are they same. The sender changes to dual guage reading.
Users browsing this forum: No registered users and 402 guests
